Old 02-02-2018, 01:00 PM
bkervaski's Avatar
Default Air Vents Tip
I notice from a lot of build pics folks, like me, are waiting until later to install the air vents.
When you finally get to this point you'll have a hard time finding a good way to hold the vents in place and apply pressure while the adhesive cures.
Here is our solution, drill a tiny hole followed up with a dab of fiberglass "next time you mix some up".
Note: Two wood blocks, one on each side. 3 inch screws, be sure to use washers.
This made the install a breeze:
Progress: Flying!
Old 02-02-2018, 05:23 PM
DaveO DaveO is offline
Thanks for the post. Do you have a web site for following the project?
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 02-02-2018, 09:21 PM
bkervaski's Avatar
@davoakes No web site, too busy building
Progress: Flying!
Old 02-02-2018, 10:40 PM
Scott Hersha Scott Hersha is offline
I clecoed mine in place with 3 clecoes to hold while the epoxy was curing - two clecoes at the back in the wide area, one up near the nose of the NACA to hold it flat. A week later, when the epoxy was fully cured, I slightly counter sunk the holes drilled in the skin for the clecoes with a deburring tool and filled them with epoxy (WFLALT)....... works fine, lasts a long time......
SH
RV-8
Cincinnati, OH/KHAO
Old 02-03-2018, 09:13 PM
I used ProSeal, and held the vents in place from the inside with 3M blue tape.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2019
