ArVeeNiner
I've been meaning to do some work on my Sam James plenum to make it fit and work a bit better. One thing that I'd like to address is the lack of accessability to the top plugs without having to remove the entire plenum. This is quite the PITA especially if you need to take a look at them when you're not at your home airport.
Has anybody ever dabbled with making either a large single panel or two smaller panels that are removable for top plug access? I figure this would be quite easy to do and with the addition of some gasket material, I wouldn't think there would be any pressure loss after reinstallation.
