I just installed my new GRT setup with a Trig T22. I will be using GRT's new approved GPS antenna as my source input, but it won't be ready for a couple more weeks. I had hoped to get TIS traffic in the interim, as the Trig is 1090ES.
GRTs manual says that the TIS data comes over the main RS-232 interface and I have that connected and properly sending'/ receiving data. I did not connect the dedicated TIS output from the Trig.
I did a test flight today, but did not get a single traffic indication, though I was getting many via ADS-B on my ipad. I was flying in Ohare approach airspace and I can't imagine it doesn't have Mode S traffic broadcast.
I am wondering if it is a setup/config issue. I programmed in all the ADS-B parameters, except for the GPS input. I am wondering if the this could cause an issue.
Has anyone successfully received Mode S data with this setup? Any suggestions? GRT is shut down for the holidays, so no help from them.
