Old 11-16-2018, 09:00 AM
rv3flier's Avatar
rv3flier rv3flier is offline
Smile
Thanks for the additional input. My hangar is going to be out of commission for an extended period of time. The lead time for replacement roof trusses is into January.
The damage is not extensive enough to total. Other than the broken plexiglass canopy, there's no damage to the fuselage. A part of a roof truss hit the r. wing tip forward edge glancing off and hitting the canopy. An 8' overhead fluorescent light fixture fell onto the top of the wing. The rest of the damage consists of the right wing tip forward of the spar, two parallel cuts through the wing skin forward of the spar a crease in the skin at the spar interface and assorted small dents on the top of the wing and three sharp dents along the trailing edge of the right flaperon. On the left wing, a crease at the rear spar interface and several small dents on the wing skin.
I've contacted Metal Innovations for an estimate.
Russ, your (Lee's) RV4 must have been going too fast --
Old 11-16-2018, 09:24 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
[quote=rv3flier;1302927] My hangar is going to be out of commission for an extended period of time. The lead time for replacement roof trusses is into January. That's irritating
I've contacted Metal Innovations for an estimate. Excellent
Russ, your (Lee's) RV4 must have been going too fast Maybe -
Russ McCutcheon
www.mccutcheonmetalfabricationaviation.com
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 11-16-2018, 09:57 AM
Sam Buchanan's Avatar
been here awhile
Prepare to be shocked when the labor estimate arrives for replacement/repair and paint to return your RV-12 to the condition it was prior to the damage. Again...very sorry you are having to deal with this situation...I know you had rather be flying and based in a sound hangar.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 11-16-2018, 11:57 AM
rv3flier's Avatar
Thanks Sam,
I followed your RV-6 build and now see that you've got a D. VII -- beautiful! Have you had any dog fights?
Old 11-16-2018, 01:17 PM
been here awhile
Thanks Sam,
Haven't had to dogfight...those pesky SPADS see the D.VII coming and turn tail and scamper for friendly territory.
Thanks for the kind comments and hoping you have a good resolution.
Sam Buchanan
1999 RV-6
Old 11-16-2018, 08:01 PM
N941WR's Avatar
N941WR N941WR is online now
Don't be surprised if it is cheaper to build a new set of wings than repair your damaged wings.
When you add in the shop labor rate, fixing things can get expensive in a hurry.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-16-2018, 11:57 PM
It is all speculation of course with none of us having actually seen the extent of the damage in this case, but I will say that there is probably not an aircraft constructed of aluminum that is any easier and quick to repair as the RV-12.
Replacing a couple or three wing skins (including professional shop labor) can be done for a fraction of the cost of just the parts to build one wing.
Scott McDaniels
Hubbard, Oregon
Old 11-17-2018, 08:17 AM
rv3flier's Avatar
Thanks for the feedback, Scott. Marcus from Metal Innovations will probably be over to Van's on Monday or Tuesday to check on parts.
Old 11-17-2018, 09:31 AM
JonJay's Avatar
JonJay JonJay is offline
Glad to see you have a path to resolution John.
Give me a call if you need some grunt as we spoke on the phone.
Looks like another Gorge wind event today. It's strange that we had no wind here and you had massive gusts just a few miles away.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
