Go Back   VAF Forums > Regional Forums > Canada
Old 05-10-2019, 04:28 PM
Jvon811's Avatar
Jvon811 Jvon811 is offline
I apply and remove the race numbers for every race with vinyl and they've been to 205+ mph and through rain and haven't come off. Comes off easy with a hair dryer.
I use one of those CriCut CNC hobby machines with about $20 worth of material. Piece of cake. Would make 12" N Numbers about a 15 minute job.
-Justin
RV-4 N249P O-320, Dual P-Mags, Warnke Prop, GRT Sport EX
Old 05-10-2019, 08:20 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Since there is no ADIZ between the US and Canada, 12" Numbers are not required.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 05-12-2019, 10:55 AM
Snowflake's Avatar
True. However he may be concerned with someone at the border flagging his 3" numbers which don't meet Canadian regulations. But that doesn't matter as he's flying a foreign-registered aircraft.
I used letters purchased at Staples to mark my RV-6 when I imported it from Idaho. The previous owner had used similar letters, so it was a simple matter to peel them off (15 years old and they came off without issue with a little thermal persuasion from a hair dryer).
After importing, I had new letters made to my specs and stuck them on. 10 years later and lots of polishing over top of them and they're still sticking fine.
Rob Prior
Old 05-12-2019, 03:57 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Easy!
If you are dealing with a sign shop, they have differing strengths of glue. You can tell ‘em that you will need to remove the numbers soonish, and they can set you up with a weaker glue. I would advise that you put a couple coats of wax on the areas that will get the numbers too.
We flew to the Bahamas in 1992 or so - peeled ‘em off in Panama City a week later. Piece o cake!
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 05-12-2019, 04:08 PM
GalinHdz's Avatar
Originally Posted by N15JB View Post
I have used blue painters tape several times. Surprisingly it doesn't blow off.
To be honest I do the same whenever I have flown an airplane across the ADIZ that didn't have 12" numbers. Cheap, they hold up to the airstream, you can remove them without any harm to the paint underneath and they do come in different colors.
Galin
CP-ASEL-AMEL-IR
2019 Dues Paid
ronschreck's Avatar
ronschreck ronschreck is offline
There is a vinyl that is used as a paint mask that is made to be removed. I have used this for temporary N-numbers and it works great!
Ron Schreck
IAC Director and National Judge
Contest Director, IAC Nationals 2019
RV-8, "Miss Izzy", 2200+ RV Hours
Track Me *** Gold Hill Airpark (NC25)
VAF 2020 Donor
"Flying makes me feel like a sex maniac in a whorehouse with a stack of $20 bills."— Pancho Barnes
Old 05-12-2019, 04:39 PM
10builder's Avatar
10builder 10builder is offline
I've used gaffers tape for making 12" numbers when flying to the Bahamas. Stays put and comes off easily at the end of the trip.
Brian S.
Arrington, TN
SPA Panther N87XP
RV-10 N104BS (Sold)
2019 VAF donation cheerfully submitted!
