Old 06-10-2019, 07:44 PM
pilotkms pilotkms is offline
Default Quick Connect
Best I came across is what Bruce Hill did. U can see it in his build site “Overthehills.com” in his RV9A project under the flaps & trim section. He put 9 pin connectors imbedded in the stick and receptical. I liked it so much I did the same. Works great. EZ to install and remove.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
330+ Hours & 7X cross the USA
2018 OSH - yes
Old 06-10-2019, 08:26 PM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
2 pin molex. Couldn't be much simpler if you've only got PTT on the copilot stick.
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Old 06-10-2019, 08:32 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Originally Posted by rswalden View Post
Mine looks like this:
https://www.dropbox.com/s/5of5q1tkml...nnect.JPG?dl=0
Works great with Infinity stick grip... 15-pin DB connector. The actual stick is drilled and tapped for a #8 hex head bolt. Easy to remove...
YES!! Thank you, Waldo. Your solution is exactly what I'm looking for, and a better solution than my DSUB CPC search:
http://www.vansairforce.com/communit...d.php?t=171499
I will shamefully copy your technique for my new sticks.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King “Beautiful Doll’s” old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePo4.
Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 06-11-2019, 12:51 AM
YvesCH YvesCH is offline
Originally Posted by humptybump View Post
An alternative is to move the PTT for the passenger to the panel (or side panel).
I often pull the rear stick in my RV-8 and decided to eliminate the wires all together. The PTT is now next to where the headset jacks are for the passenger.
Why do you remove the rear stick often? I currently fly a Champ and never took it off.. Do you remove it when you fly with chlidren?
Yves - Basel, Switzerland
RV-8 QB #83458 in Progress
Aerosport IO-360, Catto 3 blade, G3X Touch
HB-YUA reserved
Donation 2019 done
Old 06-11-2019, 07:16 AM
rswalden's Avatar
rswalden rswalden is offline
I remove mine any time I need to lay on my back under the panel to check wiring or add components. Sure beats squeezing between the sticks and having to lay on the fuel selector. Being able to remove the stick is handy if you need to reconfigure buttons on your Infinity grip, or bring extra supplies for a camping trip, or create more belly room for "horizontally challenged" passengers!
Bob Walden (Waldo), CFII-ASMEL
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 450+ Hours
RV-12 (Sold)... RV-12 Transition Training
EAA/AOPA/Vans Air Force 2019 Supporter
Old 06-12-2019, 07:52 PM
bruceh's Avatar
bruceh bruceh is offline
Default 9 pin D-sub will fit
I see Keith mentioned what I did above. I shamelessly stole the original idea from someone else here on VAF, so please don't credit me with any actual creativity.
I have dual Tosten grips and was able to get all 10 of the wires (2 of them are both ground) to fit on a 9 pin D-sub connector inside the passenger control stick tubing. Wire it up then use some 5 minute epoxy from your favorite automotive retail parts store and get it fixed in place. Then get the stick in place on the passenger side and connect it up with the other side and do the same on that end.
It works great and is easy to plug in and out.
More details and photos here.
Bruce Hill
RV-9A N5771H flown over 600 hours!
http://www.overthehills.com/RV-9A-Project
APRS Tracking for KJ6YRP and New Flying Blog
2019 VAF donator
EAA Tech Counselor
