Old 03-11-2018, 06:36 PM
KCutri's Avatar
KCutri KCutri is offline
Default VFR Night Lights
I am looking to install position/ strobe and landing/taxi lights on my finished RV-3B. Can someone recommend the best way to go about this, and suggest products to consider? Thanks.
Keith
Old 03-12-2018, 07:20 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Strobes
Hi. I installed these on my 3a. Easy to install. Not to expensive and are very bright. I purchased the model that has the tail light built into the side lights. You could see the light nicely from behind. As far as the landing/ taxi lights. I never installed them as I did not want to cut holes in my wings or modify my wing tips.
http://m.aircraftspruce.com/catalog/...hp?recfer=8776
Al Girard, Newport, RI
N339AG
RV-9
Old 03-12-2018, 12:50 PM
dacronwall's Avatar
dacronwall dacronwall is offline
Default Landing light on RV-3
My RV-3 already had position and strobes when I bought it. Mine are cut into the wing tips. Apart from stringing the wires down the wings, It would not be a huge project, but there may be some easier options.
Mine did NOT have a landing light and I needed it to be N-VFR, so I installed a cool LED one I got from Aircraft Spruce. The amp draw is super low, and it provides more than enough light. It has a 2-position toggle switch which gives you steady light or flashing. I flash when taxiing for better visibility.
I cut mine in just above the air inlet scoop on the underside of the cowl. It fit nicely without too much fiberglass work....piece of cake.
Send me a message and I can email you the part number for the light, and send installation photos if you are interested.
dacronwall@gmail.com
Cheers
Dave Cronwall
My RV-3 is more fun on accident than your Cessna is on purpose
Old 03-12-2018, 12:56 PM
jrs14855 jrs14855 is offline
Default Night
Night VFR Part 91 requires only a strobe and position lights. For many years a single strobe on top of the vertical fin was common on RV's.
Old 03-12-2018, 04:07 PM
sblack sblack is offline
But landing/taxi lights are a good idea. In Canada you only need a landing light if you carry a passenger. I guess they don't care if you kill yourself!
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
