Old 02-28-2018, 01:06 PM
Raymo's Avatar
Raymo Raymo is offline
Default RV-3 elevator re-skin
I've been asked to quote the time to replace the skin on the R/H elevator of a RV-3. Any estimates from those who have built one would be appreciated.
The trailing edge has some hangar rash (skin crack).
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 02-28-2018, 01:17 PM
rph142's Avatar
rph142 rph142 is offline
I rebuilt both elevators at the end of my build after my craftsmanship improved. I estimate it will take around 15-20 hours including time required to build the required wooden jig.
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 02-28-2018, 07:39 PM
RussellT RussellT is offline
I agree with Rob, it should be pretty straight forward. Apart from the stiffeners there is nothing else in there, so as long as you are good at drilling out rivets and the skeleton is undamaged it should easy enough. A jig will be needed to ensure it doesn't have any twist. You should be able to back drill the spar and end ribs to the new skin.
RV 3B. Very slow build
Dues paid 2017
Old 03-01-2018, 07:01 AM
Raymo's Avatar
Perfect and thanks!
Ray
NSDQ
