Old 10-16-2019, 03:34 PM
jask jask is offline
Default Question on rv6a main gear
Looking at a rv6a for sale that had a left main gear leg straightened. How would the gear leg be bent and where to look for additional damage?
RV-7 builder Ramona, CA.
Free prop balancing for Vans owners
(I am not in the business of prop balancing, just as a courtesy to meet other owners.)
Old 10-16-2019, 04:00 PM
RVDan RVDan is offline
One thing to check would be wheel alignment per the manual. The other would be the attachment weldments, and gear leg attachment holes in the weldments. Remove the nuts from the retention bolts for the gear leg and look elongation of the hole. I inspected a -6A with this type of damage and fount the holes elongated, and the gear alignment out .
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-16-2019, 06:15 PM
Ralph Inkster Ralph Inkster is offline
Look at the other legs & engine mount carefully. Engine & prop notations in the logs? Be suspicious if there isn't.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 10-17-2019, 12:35 PM
lr172 lr172 is offline
Likely from a hard landing. You want to examine ALL of the attachment point of the gear mount to the fuse and spar. I would also closely examine the engine mount attachment points and nose gear leg interface to mount as well, in case it also hit the nose wheel hard.
N64LR
RV-10 in progress
Old 11-10-2019, 11:50 PM
charosenz's Avatar
charosenz charosenz is offline
I would consult with Harmon Lang at LANGAIR.COM as he makes the gear legs, probably the most knowledgeable guys out there.
