After ordering the current Dyna mounts from Van's catalog, I have discovered that the older RV 3 engine mounts require a smaller diameter isolation mount. Anyone happen to know the P/N for these smaller mounts?
Thanks!
thank you for posting this info!! I did the same as you, ordered what is listed on spruce as current. However when they didn't fit, a quick google search showed your post and they were the correct mounts! Thanks!!
