Old 11-16-2017, 05:48 AM
MED MED is offline
If you look at the links on the Van's website, you can find Carl and Rafael's site for their RV-14A build. It has been very helpful to me.
MED
140236
N435MD reserved
Old 11-16-2017, 06:12 AM
mturnerb mturnerb is offline
Carl and Rafael's site is fantastic (rv14a.com). A number of others out there that are also excellent.
Kevin's site (http://kevinsrv14a.blogspot.ca/p/mar...orking_26.html) has links to a bunch of others and many of these are also very good.
Mine is linked on Kevin's site, but I don't know that I'd recommend it to anyone : my main purpose is documentation to support my eventual completion/airworthiness process.
TB
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 11-16-2017, 08:23 AM
n982sx n982sx is offline
Here's a link to mine, first flight was in late June. Made it to Oshkosh and now have just over 100 hours.
http://n626km.com/RV-14.html
Not as in depth as my Sonex site, or some other 14 sites, but it covers a lot of ground.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 11-17-2017, 01:57 PM
StressedOut StressedOut is offline
There's not much actual aircraft building on my website yet, but I'm pretty detailed in my descriptions. My day job is with a company that sounds like a bouncing spring and builds airplanes so I can't seem to break that habit.
If you want to see how I set up my shop there's lots there. I'm hoping to touch the first parts this weekend, but I'm a bit nervous about it. I feel I need to practice on inconsequential stuff first.
Art Jackson
RV-14A Kit#140433
Completed: Vertical Stab
Scrapped: Rudder
Working on: Empennage (HS/Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 2 November 2017
Member of EAA Chapter 92 (KCNO)
Old 11-17-2017, 10:41 PM
kiljoy's Avatar
kiljoy kiljoy is offline
I've been in IT for almost 25 years. The idea of blogging or doing ANY kind of work outside of my 9-5 IT job relating to blogging or web design makes me break out in hives. The best I can do is sped up video feed with an enigmatic and usually slightly drunken voice over commentary track.
Dues paid (2018)
RV-14 #140394
Empennage - done
Wings - Under construction
YouTube Build Channel
Old 11-18-2017, 07:06 AM
bkervaski's Avatar
Same here .. I just setup a camera to start recording when there is motion in the shop and then every night they automatically upload to Vimeo ..
Unfortunately there have been several nights that I've stumbled down to the shop to turn off the air compressor at 3am half (hopefully half) naked .. viewers beware
Progress: First Flight Prep
Old 11-18-2017, 08:33 AM
A word of caution. Most websites are first time builders like yourself. It is comforting to read how other builders, just ahead of yourself, are dealing with issues, but carefully read the RV14 manual first before following any website tips or instructions. Often times something done incorrectly on the tail, for example, will not become apparent until you try to put the tail on the aircraft. The errors on builder websites are not always corrected when found during later assembly. Most certainly read on and learn as much as possible but when in doubt stick with the plans or call Van's hot line, they are very helpful.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 11-18-2017, 09:57 AM
kiljoy's Avatar
Links or it doesn't exist
Dues paid (2018)
RV-14 #140394
Empennage - done
Old 11-25-2017, 05:08 PM
KevinPaul's Avatar
KevinPaul KevinPaul is offline
My build site is KevinsRV14A.com I have many links to many other great RV14 builders on the site. Check out the "RV Story" link along with many others. Mine is a slowww build beginning with the construction of the workshop before ordering the empennage and aircraft tools. I've already made a deposit on the empennage kit to keep me on track! Can't wait to begin!
Old 11-27-2017, 01:54 PM
Very good observation Tom. I've spent my professional life as an aircraft structural analyst (over 30 years) so I know what good and bad aircraft structure looks like. However, I'm very much a novice when it comes to actually creating parts and assemblies. That's part of the reason I got into this build, so I can learn that side of things.
Should you trust my advice on stress analysis, durability and damage tolerance issues? Most likely. I'm very knowledgeable on these matters.
Should you trust my advice on riveting, power tool usage or priming? Maybe not so much. I'm just now learning the fine details of these things.
When in doubt, call Van's!
Art Jackson
RV-14A Kit#140433
Scrapped: Rudder
