Old 11-16-2016, 09:28 AM
Tankerpilot75 Tankerpilot75 is offline
Cool Landing Lights on Existing RV7A
I flew the RV7A that I purchased from the original builder at night for the first time this week to get night currency and check things out for night time flying. My RV has halogen bulbs in the wing tips along with the position lights and strobes. My first two night landings were terrible! Didn't see the runway surface coming up at me until I was on the runway (two rather firm landings). Compensating on the third landing I flared early and landed long. My wing tip lights obviously need adjusting (upward and more centered) but I am thinking that the amount of light being projected is also insufficient.
Does anyone have a recommendation for increasing the amount of projected forward lighting? Would LED lights improve the amount of projected light? I'm concerned about heat generation inside the wing tip if I went to a higher output halogen (already have one lens with a hole melted in it). How hard are retro fit LED lights and how expensive.
Converting to wing lights isn't an option because the airplane is already nicely painted and color matching I've already discovered is next to impossible.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, Garmin 340, 335, Dual 430s, Stratux hard wired to WS, Dynon D10A (backup EFIS)
Retired - Living the dream - And going broke!
Old 11-16-2016, 01:28 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Whelen LED Light Man
That is exactly what this kit was designed for. Low cost, reasonable solution. And yes, it is more light than what you have, much lower heat.
Old 11-19-2016, 01:10 PM
[quote=Tankerpilot75;1127169My wing tip lights obviously need adjusting (upward and more centered) but I am thinking that the amount of light being projected is also insufficient.
[/QUOTE]
Interesting. I used the cheap Duckworks lights before switching to Kahuna's.
My night landings are often better than my day landings even though neither throws a tremendous amount of light down the runway.
My theory? The moment when the light DOES illuminate the runway, is a great visual cue to use in my landings. And it's always going to be EXACTLY the same from one landing to the next... it tells me exactly where I am above the runway an what I need to do the rest of the way.
Now, if there's a moose on the runway, well, that a whole 'nother story.
Bob Collins
St. Paul, MN.
RV-12iS fuselage
Builder log
Old 11-08-2017, 06:29 PM
dmattmul dmattmul is offline
Default RV-14 Lens
Anyone producing a lens with routered edges to take care of the aluminum gap around the edges? Having a mismatch between the lens and aluminum does not look good.
RV-14 QB on order !!
Enjoyed the forum very much !!
Old 11-09-2017, 10:45 AM
Dean_aeroleds's Avatar
Dean_aeroleds Dean_aeroleds is offline
If you don't want to or can't modify your tip for the Aerosun VX, we have the new Aerosun MX modular system that is now available. Here is a post showing an RV-10 with the Aerosun MX light modules installed:
http://www.vansairforce.com/communit...63&postcount=6
Old 11-09-2017, 11:59 AM
Nova RV Nova RV is offline
The PAR36 light bulb that goes in the 14 leading edge assembly is a very common size and you can pick up PAR36 LED spotlight bulb on Amazon for example for under $50 that seem to be working out on some people's builds. I bought the RV-14 LED landing light assembly kit from Vans and deleted the LEDs themselves and got all of the brackets and hardware needed to fit the PAR36 bulbs.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 11-20-2017, 08:34 PM
texdog texdog is offline
Smile Landing light
My RV6A has the original leading edge light, not nearly bright enough for me. What are some replacement ideas for the rectangular light? I would like to do it without to much modification.
Thanks!
T82 Fredericksburg,Tx.
Don't make easy hard!
Aircraft
RV6A owner
L19 sold
Dues paid 2015,16,17
Old 11-21-2017, 04:09 PM
Thanks!
This one fits: http://aeroleds.com/shop/aerosun/?val=aeroleds
Old 11-21-2017, 07:18 PM
Bavafa Bavafa is offline
In my RV7, I installed a couple of Trustfire flash light (11000 Lumen) each and they worked really great. The price of each were about $50 and they looked really cool too. These were in the wing tip and now I am thinking of same process for my 14 which is in progress but in the leading edge.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 01-01-2018, 03:50 PM
descro descro is offline
Is anyone making a wing-leading edge combination taxi/landing light? I'd like as much illumination as I can get, and am additionally considering a 'traditional' set up on the cowling.
Suggestions?
