Old 07-23-2012, 02:14 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Landing Lights
I noticed that while the wing is the same as the RV10 they realized how bad the landing light is in the wingtip. The prototype appears to have Duckworth or a reasonable facsimile in the leading edges of both wings. Factory option now?
CharlieWaffles - But you can call me "Mark"
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 11-12-2016, 10:27 PM
Bernard Hartnell Bernard Hartnell is offline
Default Wing tip lights
i did the AEROLED wing tip lights. A couple thoughts:
1: great CO., visited them in Boise. Stand behind products.
2. Great products
3. Downside: must rebuild wing tip fiberglass with their kit. Time!
4. Must add wire to harness.
5. I placed Autozone strob where landing lights were.
Bottom line: very cool but extra build time against flight time
Old 11-12-2016, 10:51 PM
czechsix's Avatar
czechsix czechsix is offline
The -14 wing kit comes with the landing light cutouts in the outboard leading edge of both wings and includes the plexiglass lenses and an aluminum mount with a round hole in it. The wire harness also has wiring for the landing lights, but the lights themselves are not included so you can go with something cheap (incandescent) or pricey (AeroLEDs or otherwise).
I agree it's a much better arrangement than putting the landing lights in the wingtip and provides better wig-wag visibility too.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 11-13-2016, 06:48 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Whelen LED Light Man
The mount is designed for the standard PAR36 light. I sell a lot of these cover plates to 14 drivers as the kit does not come with a provision for securing what ever light you choose.
The downside to the mount that comes with the 14 kit is that it is fixed in position with no provision for adjusting the angle. I have had several 14 drivers also buy my landing light mount kit and did away with the vans mount for that reason. You can order that kit without the lens since you already have one.
Old 11-13-2016, 07:05 AM
Carl Froehlich's Avatar
The real downside is current RV-14 landing light options are grossly overpriced. Unfortunally the RV-14 kit has the holes already cut out of the wing so the only option is to make your own lights. I recommend builders pre-wire but defer dumping a pile of cash on the actual lights until you want to fly at night. Perhaps someone will offer a more value based option.
While I agree that the RV-10 landing lights are not the best, they do everything I need them to do, like light up the glide slope boards at VA42 and taxi back to the hangar through the woods. With replacement bulbs less than $2 each, I'll save the rest for avg as.
Old 11-15-2016, 07:16 AM
Mudfly Mudfly is offline
Default Lights
I have not yet started the wings (on order), but I am researching lighting options. I like the looks of the Aero Leds Aero Sun VX in the wing tips. Like others mentioned though, cost and extra build time are definitely factors to consider. This builder did a nice write-up and and a great job installing the Aero Suns..http://www.vansairforce.com/communit...d.php?t=126967
However, if these lights perform as good as they look, I don't see the need for the wing leading edge lights. Unfortunately, the cut outs for the wing lights come pre-cut from the factory. I like the non wing light look like on the RV10. So, just after I ordered my wing kit I sent Vans an email asking if they could delete the pre-cut holes on the leading edges. Didn't expect a yes, but couldn't hurt to ask. As expected, they replied negative.
My next thought was to possibly cover the hole. Maybe fabricate a piece of aluminum that would fill the hole (from the inside) of the the factory cut out. I would then need to use some type of filler to smooth the leading edge.
Sounds like a lot of extra work, and given that I have not yet had the pleasure of working with fiberglass/filler, this idea may be far fetched and not even a viable option.
So, my question for those more experienced....would filling the hole be possible, and any ideas on how do do it.
Thanks.
Shawn Edwards
RV-14A (140174)
Empennage purchased (pre-owned) August 2015
www.myrv14build.blogspot.com
Old 11-15-2016, 07:50 AM
Default Filling the leading edge hole.
I thought about ways to fill the hole as well. While there are various fiberglass or carbon options, I think the easiest way would be to buy anther RV-10 or RV-14 leading edge an make both a backing ring and insert for the hole. I can only assume there are damaged leading edges out there that you can buy for shipping cost. Cut out a section bigger than the hole, this will be the backing ring. Now cut a section that fits the hole. Some rivets and you are done. If you want you can put a single layer of glass then over the whole thing then fair it in to make it look like the hole was never there.
Old 11-15-2016, 10:39 AM
Looking for a damaged leading edge sounds like good idea. I may check with Van's and see what they've got. I'll only need a small portion so several builders could use one leading edge.
Maybe someone will give this a try before me. I'm not sure I'm the best candidate to blaze this trail.
Thanks for the idea Carl!
Shawn Edwards
RV-14A (140174)
Old 11-15-2016, 07:19 PM
czechsix's Avatar
Default There are good reasons to keep landing lights separate from strobes & nav lights
Before you go to all the work to patch the landing light cutouts (which will probably never look quite right), here's some food for thought. I've observed both an RV-7A and RV-10 at night with the landing lights integrated into the wingtip, and there were two things I did not like about them:
1) With the landing lights on, the nav lights become much less distinct...I noticed the red light in particular ended up looking sort of a pale pink color. There's just so much light being output by the landing light, including a fair amount of internal reflection off the plexiglass lense, that the nav light gets overwhelmed by all the white light. The strobes also looked less distinct.
2) The wig-wags are less distinct when blended in with the nav lights and strobes, and they are also effective over a narrower angle ahead of the aircraft. This is because when the landing light is in the wingtip, a portion of the tip protrudes ahead of the light and reduces the angle at which it's visible in the direction inboard from the light.
Bottom line is if you keep the landing lights in the leading edge cutouts as designed, you'll save yourself some work, your aircraft will be more visible to other aircraft due to the more distinct wig-wag effect, the wig-wags will be visible over a wider swath of airspace reducing chances of collision from your left or right, the strobes will be more visible, and the nav lights will be more effective in communicating the orientation & direction of travel (as intended) to other pilots.
FWIW...
Mark Navratil
Spring Hill, KS
Old 11-16-2016, 07:54 AM
Default Good points
FWIW...
Very good points Mark. Also, you are probably correct that my patch job would "probably never look quite right".
Thanks for the advice.
Shawn
Shawn Edwards
RV-14A (140174)
