Old 12-06-2017, 05:37 AM
steve murray's Avatar
steve murray steve murray is offline
Anybody have some pictures of the firewall location for fuel return location? The links to pictures in the previous posts are dead.
Much appreciated
Steve
RV8 Flying since 2007
RV10 in construction (Fuselage)
Old 12-06-2017, 08:40 AM
Default Return
I am using an EFII system. My return line is symmetrical with supply but on the opposite side of the tunnel. Supply runs forward on the left side of the tunnel and through the firewall. Return runs forward on the right side of the tunnel and through the firewall. Both pass through the firewall below and outboard the heater vents, similar to where section 37 in the plans details.
I opted for steel fittings...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 12-06-2017, 08:59 AM
Much appreciated
I was looking for the same thing last night. I found pictures from Carl Froelich and maybe one other builder, plus some other discussion. Carl's picture showed his return location as basically the same location as the fuel line, but mirrored on the left side of the firewall. Someone else suggested a location just below the fuel line penetration.
I'm planning to use the mirrored location.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 12-06-2017, 09:42 AM
Default Return
Thatís how mine are...
Supply on the left, return on the right...
Bob
Doors - Done
On Gear
290 HP Barrett Hung
Old 12-08-2017, 07:40 AM
BGS's Avatar
BGS BGS is offline
Default Return
Here is where I placed mine. If you do use this location, be careful on how high you go as it will interfere with the engine mount. Mine cleared by about 1/8"
Brian Steeves
#40955 RV-10 - N413BS - Sold
It is Airworthy and Flying. But are they ever done?
First Flight 9/28/2013
#41714 RV-10 - N272BS
Ready for Inspection on 6/12/2018
#120849 RV-12 - N112AB
Flying. First flight Nov 26, 2017
Challenger II - N272MP - Sold
First Flight in 2011
www.briansrv10.com
Old 12-08-2017, 07:43 AM
Auburntsts's Avatar
You might want to consider replacing those aluminum fittings with steel ones.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 12-08-2017, 07:46 AM
BGS's Avatar
BGS BGS is offline
Default Returns
Yep, Plan to do that. Did not have any on hand so used these to fit.
Was only going to change the ones on the firewall. Is it recommended to change the ones in the tunnel as well?
Brian Steeves
www.briansrv10.com
Old 12-08-2017, 07:51 AM
Auburntsts's Avatar
Nah. Just best practice to use steel for fuel line fittings and to firesleeve fuel lines FWF. Everything firewall aft can be aluminum.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
