Old 01-01-2009, 02:40 PM
Wayne's Avatar
Wayne Wayne is offline
Default firewall placement of fuel return fitting
I plan on using a IO-540 with a purge valve and thus need a fuel return line back to a tank. Since I dont have the engine yet and unsure of firewall "clutter" I was wondering where to put the bulkhead fitting for the return fuel line? It would be nice to install this with the wide open spaces as I am doing the rest of the fuel system.
Wayne
RV 7 "eh?" C-GOYA - 420 hrs
RV 10 C-GOOH - 350 hrs
R44 160 hrs
grounded by stroke Sept 3/07 - and back flying Feb 2010. Don"t ever take flying for granted !
Old 01-01-2009, 11:08 PM
Deems Davis Deems Davis is offline
Default Here's where I put mine
purge line coming from purge valve
http://deemsrv10.com/album/Sec%20FF4.../DSC04985.html
purge line as it enters the center tunnel (enroute back to fuel tank)
http://deemsrv10.com/album/Sec%20FF4.../DSC04988.html
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 01-02-2009, 09:03 AM
Wayne's Avatar
Default thats what I needed
Thanks Deem - thats what I was looking for. I had actually gone to your site and couldnt find the pic I needed.
Have a great 09
Wayne
R44 160 hrs
Old 01-02-2009, 10:23 AM
David Clifford David Clifford is offline
Banned
Can anyone tell me what the purge valve is for or does? When I plumbed the Cozy MKIV with a Superior XP IO-360, I did not use one and it starts and runs just fine. I am a ways off the decision point on my RV-10, but I do plan on using an IO-540 and would like to know if I should plan on using one.
Old 01-02-2009, 10:47 AM
Releases pressure from system at engine shutdown.
Acts as a backup engine kill.
Allows heat soaked fuel to be purged for easier hot starts.
Old 01-02-2009, 11:39 AM
w1curtis's Avatar
w1curtis w1curtis is offline
And sometimes act as a primary engine kill at the most inopportune time when not properly safety wired.
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” - Dr. Suess
Old 01-02-2009, 12:28 PM
Yep, that was a big concern of mine.
I chose to use a different shaped/colored knob (handle?) for my purge control, and mount it slightly away from the primary engine controls.
http://aycu32.webshots.com/image/409...3100502_rs.jpg
Chrome "T" handle to the left of the black throttle knob.
It is also recessed a bit under the panel.
Old 01-02-2009, 01:00 PM
DanH's Avatar
DanH DanH is offline
A few notes:
The firewall bulkhead fitting should be steel, not aluminum.
Locating the fitting and its line someplace other than the lower firewall cooling air exit region is a plus...fire follows airflow.
Consider backflow. Many installs run the purge line directly to a tank, or to a fuel supply line somewhere inboard of a tank. If the hose burns off a purge line firewall fitting mounted below the tank fuel level, there is nothing to stop gravity flow of fuel into the fire. A purge line firewall penetration mounted at some reasonable height above the fuel supply is one answer (easy with an RV). The other approach is a check valve in the purge line somwhere behind the firewall.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-02-2009, 01:24 PM
A few notes:
Dan, excellent observations.
Check valve ----- never thought of it.
I wonder if a high loop would do??
Old 01-02-2009, 01:33 PM
frankh's Avatar
frankh frankh is offline
Default I put mine up high
To avoid the gravity backflow if the line somehow broke off north of the firewall..Highly unlikely but as I had the option then why not.
Not sure what system your using but the 4 banger AFP system's purge valve is to th right of center line on top of the engine.
I basically came straight back, thru the rear baffle so my firewall hole is up high in board of the upper right engine engine mount.
Steel bulkhead fittings are available for cheap from your local hydraulics shoppe.
Frank
