Old 12-05-2017, 07:05 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Rotax Screw ID help needed
I found the screw shown below sitting on the left carb drip tray. Sorry the photo is rotated 90 degrees. I have searched for the spot it came from but have not been able to locate its origin.
Four additional RV builders were also unable to figure out where it came from. It is most definitely a Rotax screw because the torque seal color is an exact match to the torque seal they used on the rest of the engine. I noticed the screw before I had connected the throttle cable. It is tiny and I do not know what to call it so I can not look it up in the parts list. Any one have a clue?
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
[COLOR="rgb(46, 139, 87)"]=VAF= Paid up 2018[/color]
Old 12-05-2017, 07:09 PM
AndrewR AndrewR is offline
Looks like the throttle stop screw?
You should be able to spot a similar one on the other carb.
Old 12-05-2017, 07:14 PM
I just edited my post. I noticed the screw a month or so before I ran the throttle cables.
There is not another screw this size on the other carb that is visable
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
Old 12-05-2017, 07:29 PM
In the illustrated parts catalog carburetor diagram I would say it is part 45, 963162 THROTTLE VALVE STOP SCREW.
I don't have a carb in front of me, but from the diagram it goes into the bracket that the springs attach to to pull the carb open. From memory it isn't an actual nut, more of a threaded spring washer sort of thing.
Or I could be wrong and it's something else entirely
Old 12-05-2017, 07:54 PM
waterboy2110 waterboy2110 is offline
Has this engine ran yet? Connecting throttle cables implies it hasnít. It looks like the screw you remove to tap into the balance tube for the MAP sensor.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
Old 12-05-2017, 08:26 PM
Piper J3 Piper J3 is online now
Originally Posted by waterboy2110 View Post
Has this engine ran yet? Connecting throttle cables implies it hasn’t. It looks like the screw you remove to tap into the balance tube for the MAP sensor.
Do you mean the screw on top of the intake manifold that you remove, and in its place, you screw in a barb fitting for rubber hose connection to vacuum gage for balancing carbs? By memory, that looks like the screw...
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 400
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 12-05-2017, 08:58 PM
There’s a small screw that you remove from the balance tube (the tube that connects the two intake manifolds) It has barbs on the port and is closer to the left side. That’s what it looks like from the pics. If you’ve hooked up the tube pull it off and see if the screw fits. I can’t recall another screw like the one in MAP port.
PP - ASEL
Instrument Rating
RV12 Flying.
Old 12-05-2017, 09:08 PM
I have not run the engine yet. I will investigate tomorrow and advise.
I do not want to run the engine till I figure this out.
Thanks for your suggestions!
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
Old 12-05-2017, 09:14 PM
I think you are talking about #13
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
Old 12-05-2017, 09:18 PM
Thatís the one Iím talking about.
PP - ASEL
Instrument Rating
RV12 Flying.
