Old 12-05-2017, 05:55 PM
albertaflyer albertaflyer is offline
Default FS MA-4SPA carb
Hi,
I have an MA-4SPA carb for sale. Removed in working order for an electronic ignition/injection upgrade. $820 for rebuilt one from ACS. offers? Please be reasonable... I donít need it, but Iím not giving it away even if it is almost Christmas!😁
Old 12-05-2017, 06:39 PM
Eric Petersen Eric Petersen is offline
Default part number please
Could you please identify the specific part number? There are multiple versions of the MA-4SPA.
Thanks.
Eric
Old 12-05-2017, 08:36 PM
Part number is 10-3678-32
Old 12-06-2017, 08:12 AM
FYI... a $200 offer is not reasonable.
Old 12-06-2017, 06:53 PM
Default more info?
Thanks for the part number. Could you provide more info?
History of carb/age, rebuild status, new blue float?, what engine/airframe/prop was it in service with?
I am currently flying an RV-6A with an O-320D1A with a constant speed prop using a MA-4SPA pn 10-5217. This carb seems to be too lean, and I am considering my options.
Thanks (and no I did not offer $200 for it, but may consider ~$500 depending on the questions above).
Eric
Old 12-07-2017, 10:35 AM
patterson patterson is offline
Default Richen the Jet
Eric,
All you would need to do for your carb is take out the jet and carefully ream it a couple thousands (at a time - careful, go slow) until you reach the desired EGT and FF you need. Search the threads on this site about this option.
Ron
Ron
RV-4 N8ZD Sold
F4 Raider under construction
regular VAF donor despite being exempt
Old 12-07-2017, 09:19 PM
Default re: reaming the jet
Ron,
Thanks for the input. I have read quite a bit on that option, and may well go that way.
What confuses me somewhat is that I had 200+ hours of satisfactory operation before this happened. So I have been chasing everything else I can think of before going into the carb.
Eric
Old 12-08-2017, 09:54 AM
Ethanol1 Ethanol1 is offline
Default Carb
Eric,
I may have one you can try. Iíll look at the part number later today. On a plane from Calgary to msp now. Planning to go the RV gathering tomorrow and can bring it if itís the right one.
Mike
Mike York
President EAA Ch 25
Old 12-08-2017, 11:20 AM
lr172 lr172 is offline
Originally Posted by Eric Petersen View Post
Ron,
If it became lean when it used to be fine, I suggest a tear down and cleaning. It is possible that you got some build up or trash in the jets or the circuit (i.e. passage ways). Also, the float setting could have driffted, which would also affect the delivered fuel rate.
N64LR
Old 12-08-2017, 07:59 PM
Default Re: carb
Mike,
I plan to be at the mnwing gathering in the morning. Hope to see you there!
(I don't know what part number is right, i just know what I have...)
Eric
