Old 12-05-2017, 09:09 AM
dmat dmat is offline
Default WTB: Fuel Servo and Injectors (AFP or Bendix)
I keep going back and forth on converting my FADEC back to fuel injection.
I have all the parts to convert back with the exception of a overhauled fuel servo and injectors for a O-360-A3A.
I have a bendix servo but it needs to be overhauled. Can I overhaul myself? If so, know where I can get an overhaul kit?
Does anyone have injectors and an overhauled servo? I would prefer Airflow Performance FM-150.
I am also thinking about doing a top overhaul while I do the conversion so if anyone has cylinders for the above engine, please let me know.
D
RV6A - N6389 - flying regularly
Old 12-05-2017, 11:12 AM
Electrogunner Electrogunner is offline
Default Bendix servo
There is a bendix servo and distribution block further down in classified if interested. Sorry not sure how to link it.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Garmin 900x
Whirlwind 3 blade
Emmpenage 99.9999% done
Wings 99.99998% done
Fuselage SB 90.1% done. I think
Fuselage and tailcone is one.
Old 12-05-2017, 11:21 AM
I think I saw that ad already. It was for the bendix which needed an overhaul. and the avstar looks good but after speaking with avstar, that specific servo doesn't fit a 180hp O-360. It's meant for a 200+HP.
I would prefer one that doesn't need overhaul.
Old 12-05-2017, 11:23 AM
Raymo's Avatar
Raymo Raymo is offline
D
Call Don at AFP. He can overhaul your Bendix servo along with doing the flow test, which you can't do, and provide all the parts required to get you going.
Don George, in Orlando FL can OH your cylinders.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 12-06-2017, 07:20 AM
Red Mtn flyer Red Mtn flyer is offline
Default +1 for Air Flow Performance
Just got my RA5 back from Don [now an EX-5]. They won't up-sell you, they do this stuff all day every day, and the cost was actually lower than predicted.
Ben K.
RLSA - A,G,W/S
Falco F-8L
50 yrs of flight and counting
Old 12-06-2017, 01:40 PM
jwyatt jwyatt is offline
I have an FM-100 entire kit available -- servo, spider, purge valve, lines, clamps, injectors.
Joshua Wyatt | Goodhue, Minn.
RV-9A N627DW @ KRGK - Flying since 2012
rv9a.pacificrimsound.com
Old 12-06-2017, 02:51 PM
Yeah, I have been talking with Don and he is a great guy. Planning on heading down to SC to do the swap early next year.
Old 12-06-2017, 10:55 PM
Don will be checking my Servo and if not usable, it will be converted to an ex5. No need for the servo but if anyone has:
- nozzles/ injectors for an O360
- divider mounting bracket
- etc
- spark plugs
I have the following for the conversion already:
- servo
- mixture cable
- bendix mags
- divider
- fuel lines (currently on fadec which I believe are usable)
D
