Old 12-04-2017, 03:35 PM
gear1 gear1 is offline
Default Help -Grove landing gear on RV8
A question for those who have gone before:
Will the standard Van's gear leg fairings fit over the non-airfoil Grove aluminum gear legs? I am replacing the standard van's steel gear legs with the Grove non-airfoil gear legs, and hope not to have to recreate the gear leg and intersection fairing. Any help and/or photos that y'all could provide would be most appreciated. Any advice on installing the Grove gear legs would be appreciated.
Craig Taylor
RV8 flying
2018 VAF dues paid with thanks
Navy A7E Viet Nam era
Ret. Corprate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
Old 12-04-2017, 03:55 PM
xblueh2o xblueh2o is offline
I don't think the normal RV-8 fairings will fit.
In order to fit around the Grove non-airfoil legs I think you have to get the fairings for the round gear aircraft Van's aircraft (RV-7, RV-9).
Hopefully somebody will know for certain.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 12-04-2017, 05:05 PM
scard's Avatar
scard scard is offline
Always fun to see Goliath post.
We hope to see you again soon.
Scott Card
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Track
Old 12-04-2017, 05:16 PM
skylor's Avatar
skylor skylor is offline
Default Gear Leg Fairings
I use the non-airfoil grove gear (which I love), and I'm quite certain the stock fairings won't fit because the grove gear is much thicker at the fuselage end of the legs. I purchased a pair of F1 Rocket leg fairings which I had to modify because they're actually too thick. I modified them by slitting down the leading edge, removing ~ 1/16" of material from each half, then reglassing them back together with the trailing edge squeezed together a little bit. Sounds like a pain, but I was able to modify both fairings in about 2 hours of work time over 2 evenings. Of course you will have to create new intersection fairings which IS a little bit of a pain.
I think the end results are worth the effort, however. I think the finished shape is a bit better on "my" fairings than the airfoil gear, end it is also several pounds lighter (4+), all up, than the airfoil gear..
Skylor
Old 12-05-2017, 07:42 AM
A2Jake's Avatar
A2Jake A2Jake is offline
Default Grove Gear Fairings
I just finished this step.
I stressed over this exact same issue for a year and a half, knew it was coming……..
No ones fairings will fit unfortunately.
With this being the last hurdle before paint, I just stepped up and DID IT.
Laid up the gear fairings and both upper and lower intersection fairings.
Im Very happy with the results mostly because they fit "MY" airplane.
Its not that big of a deal once you force yourself to get started.
I have photos but they are not hosted to post here at this time.
J.
RV-8 Project Rebuild
RV-8 Fastback New build
Cessna 195
Old 12-05-2017, 09:16 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
I bought mine from Team Rocket.
William Slaughter
Houston, TX
RV-8QB FF complete, baggage door done. Fiberglass work mostly done. Now at the airport for final assembly.
Old 12-07-2017, 09:20 AM
Default Thanks!
Thanks everyone for your kind replies! I have a better idea of what I am up against now.
For those who have converted from the Van's steel legs to the Grove gear, are there any mechanical issues that I need to be aware of? Thanks!
And, Scoot, when is the next Midwest FFI Clinic?
Craig Taylor
RV8 flying
