Old 12-04-2017, 02:35 PM
az_gila's Avatar
az_gila az_gila is offline
Question Fuel valve location Q.
I'm removing the Vans fuel selector and mounting an Andair valve in the -10 QB kit I bought. At the same time I'm relocating it 3 inches down to copy the newer factory location.
It would be easier assembly and fabrication for me it the valve could move 1 inch or so further forward.
Can anyone with a finished -10 tell me if this could cause problems? I plan on using the AeroSport center console it that makes a difference.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-04-2017, 02:52 PM
The center tunnel top has a hole for the valve shaft pre-drilled, so you'll need to patch that in some way. Check that the valve handle/pointer will clear your center console in the new location. Obviously none of the fuel line bends will be per-plans if you move forward, but I don't think there's anything that can't be made to work. I'd strongly suggest the mod some have done, of putting a side access panel into the bottom of the tunnel, to get a wrench in there for R&R the fuel filter. Going from the top is painful, and with the valve more forward may be even harder, not sure.
Old 12-04-2017, 03:11 PM
It is a pain if you have to loosen shoulder harnesses whenever you want to reach the fuel valve.......
Scott McDaniels
Hubbard, Oregon
Old 12-04-2017, 06:58 PM
az_gila's Avatar
Question
Yes, I understand that, but would <1 inch make that much difference?
Gil Alexander
Old 12-05-2017, 07:43 AM
jwilbur jwilbur is offline
I'm using the Andair valve in the stock location with the AeroSport center console. Here is a (bad) picture.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 12-05-2017, 09:04 AM
I can't answer that... everyone's body is slightly different.
If you were able to just barely comfortably reach it in the stock location, 1" fwd could cause it to be a stretch.
I am 5'9" and about average leg to torso proportioned (30" inseam).
When I fly either of our RV-10s (with the rudder pedals in the center mounting position) and my shoulder blades remaining against the seat back, I can just reach the fuel valve with my arm fully extended straight. I don't feel like I am stretching to reach it but I would be if it were any further fwd.
If using the center console raises the elevation of the handle that would offset/improve any fwd move slightly (but I am not sure how much).
Scott McDaniels
Hubbard, Oregon
Old 12-05-2017, 12:14 PM
az_gila's Avatar
Thanks Scott.
The center console keeps the fuel valve at essentially the same elevation, so I'll work on new bracketry to keep the valve handle in the stock location.
The revised brackets are needed since I'm dropping the actual valve down 2.5 to 3 inches inside the tunnel like the later kits.
The Andair valve and it's extension arrive from the UK today.
Gil Alexander
Old 12-05-2017, 01:36 PM
rvdave rvdave is offline
I must have an earlier kit with a higher bracket, why the change?
Dave Ford
Cadillac, Mi
Old 12-05-2017, 04:02 PM
Flandy10 Flandy10 is offline
Gil,
Are you using the Andair extension?
It does have two universal joints that may allow you to move the actual valve location forward without moving the handle.
Scott Flandermeyer
Rv-10 TDI #40816
Fayettevile, GA
2018 VAF Donation complete
Old 12-05-2017, 04:32 PM
Change was made around spring 2008. It simplifies the routing of the rear seat hot air SCAT. At the same time the fuel line routing was simplified. It came with a extension for the valve shaft, and a much nicer handle with a pull-up-to-unlock feature. Even I - who self-admits to having no aestetic tastes - thought the original handle did not look like it belonged in an airplane.
