Old 12-03-2017, 07:58 AM
Tsabean Tsabean is offline
Default Rudder Bottom Fairing Strobe Light
Anyone have a photo of how a Whelan strobe light is fitted to the R-411 fairing on the bottom of the rudder?
I've searched the archives but can't find one.
Thanks, Tom
Old 12-03-2017, 08:01 AM
Walt's Avatar
Walt Walt is offline
You might want to have a look at the AeroLed tail light, much more compact than the whelen unit and fits in the fairing with no mods.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 12-03-2017, 08:06 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Cleaveland Tools
http://www.cleavelandtool.com/Tail-L.../#.WiQSu2co5l8
This was helpful to me.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 12-03-2017, 10:57 AM
n82rb's Avatar
n82rb n82rb is offline
Forget both of them and get the one from Paul at flyleds. To mount any of them I made an aluminum tin that I bonded into the fairing.
Bob burns
Rv-4 N82rb
Old 12-04-2017, 01:11 AM
chiricuca chiricuca is offline
https://www.flickr.com/photos/125835.../shares/pQ70v7
Old 12-04-2017, 01:13 AM
https://www.dropbox.com/s/ockssb1qf0..._Ring.pdf?dl=0
Old 12-04-2017, 03:00 AM
BMW_X6M BMW_X6M is offline
I retrofitted from a standard lamp housing assembly to the AeroLeds Tail strobe and it fit easily. I made a spacer out of aluminum to fill in the depression from the old lamp mount. I was then able to use the existing mounting holes. It fit inside the existing mount with no other mods. I did have to run a new cable all the way to the panel though. The LED required more wires. I love the added strobe on the tail.
Old 12-04-2017, 03:21 AM
rzbill's Avatar
rzbill rzbill is offline
For the minimalists, there is another way that makes the adapter rings posed previously just extra undesireable weight.
Years ago, the method was to obtain some 'Marine-Tex' filled epoxy, glob it in behind the 2 holes in the fiberglass and then drill it and tap it to fit the light.
I modified this by using Marine-Tex to glue in a couple of brass threaded inserts I got from the local RC hobby shop.
A bit of TLC to the fiberglass to get it dead flat for a good interface to the light body and you are done.
Link to the tail light page
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
