Old 12-01-2017, 06:50 AM
Fearless's Avatar
Fearless Fearless is offline
Default Nose gear breakout question
I just need to confirm that when setting the breakout force on the nosegear - you set it with the tire just touching the ground and not with the full weight of the plane on the nose gear.
When landing my nose wheel seems to be flopping side to side on initial touchdown. It seems fine when taking off.
Mike
RV-9A Based K6I2
Working on Phase 1
Building RV-12 with brother
Old 12-01-2017, 06:51 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Nose wheel not touching the ground, pull at axle location 90 degrees to swivel.
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
Old 12-01-2017, 11:57 AM
Raymo's Avatar
Raymo Raymo is offline
If you haven't already, consider the Anti-Splat nose wheel bearing mod. They also sell a nice digital spring scale for measuring break-out force.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 12-01-2017, 12:11 PM
Default Nose gear flopping
Mike there will be rare occurrences of flopping nosewheel. I had it several times and it is not necessary attributed to breakout force. Might be hot landing while fighting a strong cross wind you touch the runway with NW then raise it being a bit sideways. It stay cocked due to low airflow and bounces when you try to glue it...
Old 12-01-2017, 09:48 PM
I'm getting some light nose-wheel shimmy on landings at 200 hours...it has developed in the last 20 hours or so, and I'm thinking it might have something to do with imbalance of the wheel/tire as a result of tire wear. So check all the usual suspects!
I just bought a motorcycle wheel balancer and some balance weights, and will check/adjust the break-out force. Should be completed by Wednesday, and I'll report back here.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2018
