Old 11-30-2017, 07:34 PM
bkervaski's Avatar
Default Avionics: Everything is 2 days ...
Wow, even with a prefab panel and harness there are so many small things you need it's hard to prepare. Everything is going slow having to order a bit of this a bit of that one of those and two of these. Learning how to build this connector, use a solder sleeve, build that connector. Routing wires is an art form. Shipping is killing me and my tool count is going up again daily! How many different crimping tools can one own anyway?
Progress: Away for PAINT
Old 11-30-2017, 07:42 PM
One less than you will end up needing
Old 11-30-2017, 07:56 PM
YellowJacket RV9 YellowJacket RV9 is offline
Think how much quicker your second build will be though!
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 12-01-2017, 05:08 AM
maniago's Avatar
maniago maniago is offline
I'm in the same boat. I've spent maybe $700 on bits and pieces, tools etc to wire up the avionics and it all fits in a very (emphasis on very) small box. Just like everything on the plane, when you show it to someone, they say, pffft that cant take long. Then you describe the steps you go thru to just rivet one rivet, or in this case, make one wire connection and its ridiculous.
In the builders club, the secret handshake is actually the silent "head-nod of knowing".....earned by doing, not by talking.
Build on!
Mani
MustangII (FoldingWing) "FirewallFwd&sundries": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 12-01-2017, 09:36 AM
Ironflight's Avatar
VAF Moderator / Line Boy
This is why the homebuilder's math (90% + 90% = 100%) is actually true.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-01-2017, 10:24 AM
Rupester Rupester is offline
Yep .... we all understand, especially the shipping part. The good news is that even with all the crimpers and specialty tools, wire, connectors, fittings, switches, etc; the total cost of wiring is peanuts compared with the other major task areas. For me it was the least cost by a wide margin. Part of the frustration results from timing .... all this "stuff" comes later in the build when u thought you had all the tools you needed!
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 12-01-2017, 10:28 AM
pvalovich pvalovich is offline
Default Wiring Lessons Learned
Nearing seven years and 950 hours, even though my -8A operates flawlessly, the one thing about the build I regret is not taking the time/attention to detail installing the wiring. Its not the ops its the really excess frustrating troubleshooting time that drives me nuts.
From unreadable labels, to sloppy wire runs, to stupid cut-it-too-short decisions, there is a lot of room for improvement, if and when I can convince the wife that I need another airplane. At least I'll have the specialized used-it-once tools and a zillion bit parts for the job.
Old 12-01-2017, 01:13 PM
Raymo's Avatar
Raymo Raymo is offline
I gained some avionics skills in the 90s that I put into use helping others while I was building at another airport. Now that I have moved my finished plane, I've had to start acquiring 2 sets of crimpers and various supplies to support other builds. It helps that I get paid for my help!
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 12-01-2017, 01:51 PM
bkervaski's Avatar
It's alive .. and didn't explode .. woohoo!
Old 12-01-2017, 03:58 PM
KeithB KeithB is offline
Congratulations. Lighting it up is one of the most gratifying milestones.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >350 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
