Old 11-30-2017, 12:00 PM
ALagonia ALagonia is offline
Default 6A versus 7A
I would like some real world opinions from those that know both models of the difference in value between an equally equipped 6A and 7A. Also some opinions on resale value between the two a few years down the road. And if anyone wants to add their real world actual experience of the difference in flying qualities between the two that would be very helpful.
I am trying real hard to own an RV.
Thanks guys
Old 11-30-2017, 01:41 PM
Raymo's Avatar
Raymo Raymo is offline
Lots of differences but I believe the biggest is the MGW due to different spars and other improvements.
RV-6 = 1600 lbs
RV-7 = 1800 lbs
Max fuel:
-7 = 42
-6 = 38
-7s sell quickly for a premium while -6s are less pricey and more available (more built, to date).
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 11-30-2017, 03:12 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
They fly closely enough that most wouldn't be able to tell a difference between the two. There are, of course, subjective opinions but for the most part I think builder preferences and options are probably more important than the airframe differences.
The -6A has a recommended gross weight of 1650lbs, while the -7A is at 1800. Many -6As are at 1750 or 1800 as well since it's up to the builder. Fleet experience seems to suggest that isn't unreasonable.
The -7A has a higher acro gross weight, but I think attributing this to wing strength differences is folly. I doubt the wing would be the thing that would fail first, actually - it's usually the tail feathers. I am not aware of an in-flight failure of an RV-6/6A wing so the strength difference between the two isn't really significant.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 11-30-2017, 04:01 PM
koupster's Avatar
koupster koupster is offline
Default Agree with Brad
I bought a 6A because I thought it was a better value than a 7A.
Cheers, David
RV-6A A&P
Old 11-30-2017, 04:25 PM
bret's Avatar
bret bret is online now
Buying or building? if building I pick the 7, if buying on a budget the 6. I think you can find a 6 cheaper than the cost to build one.
2018 gladly supported
Old 11-30-2017, 04:50 PM
Kyle Boatright Kyle Boatright is online now
Thanks guys
Similarly equipped, with similar build quality, and similar hours, a -7a will be a bit more expensive than a -6a. The bottom of the -6 market is lower than the bottom of the -7 market because of age, equipment, and build quality, but unless you're bottom feeding, that may not be a big deal.
The -6 should be slightly sportier to fly, and the -7 will have a bit more useful load, fuel tankage, etc.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-01-2017, 08:20 AM
Thank you all for your comments. This may very well be my last airplane and i just want to make the right choice.
