Old 11-30-2017, 10:18 AM
JumpJack JumpJack is offline
Default IO-540 Oil Dipstick
Hello all,
I have been searching for a replacement dipstick, for the 540 that came out of our Lancair. It originally came with markings on it that did not match up with actual levels. So, I used a pipe cutter to make new marks, and that has always worked ok. The problem is thereís two sets of markings, one with numbers and mine with just the lines. Itís always a little confusing.
So, 2 questions: Where is the best place to source a replacement? Iíve found the appropriate part number (LW-14756), and a few places that carry it, but there are no images so I have no idea what Iím actually getting.
Second, whatís the best way to mark it? (Not get the levels, I have that) but how to actually mark the tube with numbers and tick marks.
Any help appreciated.
Jack W.
RV-10 Wings in Progress
Old 11-30-2017, 10:21 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
I have the exact same issue, and would love to find an answer.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 11-30-2017, 11:05 AM
ChuckEllis90b ChuckEllis90b is offline
I have a dipstick and adapter for sale. It came off my IO-540. Number 7360 is in raised lettering. $50 plus shipping. If interested contact me at Chuckellis90b@netscape.net
Old 11-30-2017, 03:35 PM
Thanks Chuck, but the problem might be he same. I doubt the markings will line up with the oil levels on my engine. If you have a picture, maybe we could measure from the top and see where yours are marked compared to mine
Jack W.
Last edited by rv7boy : 12-09-2017 at 12:02 AM. Reason: Rules for ads (in quoted post)
Old 11-30-2017, 03:53 PM
Paddy's Avatar
Paddy Paddy is offline
Default Dipstick
If you clean the dipstick well with some alcohol, you can mark it with a sharpie. I've done this to mark the intervals between the 3qt increments on my own engine's dipstick. The marks stay on surprisingly well and could just as easily be put to work to distinguish the marks you want from those you don't. Works well for making a fuel dipstick too with some acrylic tube. Sharpies seem impervious to petroleum products, but not isopropyl alcohol.
Flying as of 10/30/16 after 8 yrs building
Old 12-01-2017, 07:01 AM
1001001's Avatar
1001001 1001001 is offline
If you want to delete the original lines, you might find someone who has a small lathe and just turn the diameter down there. Use a nice radiused tool and there should be no question which are the correct reference lines.
As far as marking numbers, I'd suggest getting a small stamping set from Harbor Freight and just directly stamp the numbers in place. To do it best, you can make a stamping guide by through-drilling a block of wood with a drill of the same diameter as the dipstick and then cut the block in half through the axis of the hole. Then drill a cross-hole slightly smaller than your stamps and finish the edges with a small file (if the stamps are square). Then clamp the dipstick in a vise using the wood block. The cross-hole will then align the stamp properly and prevent it slipping off the dipstick when you mark it. If you are really careful you can probably do without the guide block as long as you clamp the dipstick down well when you are marking it.
Old 12-01-2017, 07:12 AM
Skysailor Skysailor is offline
Default There is a roll pin
There is a roll pin in the top of the dipstick that goes horizontally through the cap. Carefully measure from the cap to the 12 Qt line. Drive the roll pin out of the dipstick assembly. Insert new dipstick to same measurement. Drill new dipstick for roll pin and cut off any excess above the cap. Drive in new roll pin.
RV4
Paid through 2018! How about you?
Old 12-01-2017, 07:51 AM
659JR 659JR is offline
I have a LW-14756 17 13/16 from the flange to the bottom of the stick, 13 3/8 at 12qt, 14 1/4 at 9qt, 15 5/8 at 6qt and 16 11/16 at 3qt.
Jesse
Originally Posted by JumpJack View Post
Hello all,
Old 12-01-2017, 09:48 AM
Jesse
Is that one you want to sell?
Iíll take some measurements on mine this weekend.
Jack
Jack W.
Old 12-01-2017, 10:09 AM
Default dipstick
Yea I could! Let me know the part number on your fill neck and Ill make sure the tread size is the same.
Jesse
