Old 11-29-2017, 04:14 AM
SG777 SG777 is offline
Default Left Throttle for RV7 Left Seat
Would like to configure my RV7 with a second throttle on the left side. Pictures and recommendations appreciated. Best, Shawn
Old 11-29-2017, 04:29 AM
74-07 74-07 is offline
Default Throttle quadrant
Shawn,
Our RV7 has a left side quadrant. As a couple of ex-Air Force pilots, my son and I really like it. We previously owned an 8 and, of course, it had the same. In addition to just feeling right, it really opens up the space between the bottom of the panel and the floor. I've yet to figure out how to post photos here but if you would pm me your email, i can send lots of photos. Our panel is out right now for upgrade so I can send detailed photos if you like.
Rob
Old 11-29-2017, 05:22 AM
Chattin35 Chattin35 is offline
Default Recommend
I recommend against that config. It adds unnecessary complication and time to the build.
If you like flying stick right hand throttle left, just fly the plane from the right seat. Thats what I do.
Old 11-29-2017, 05:28 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default VAF Search Engine is your friend
Shawn,
Use the VAF Search to your advantage for finding info on this subject or any other build info. Here’s what I found:
http://www.vansairforce.com/communit...rchid=33605594
Oh, and hey: Welcome to the VAF!
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King “Beautiful Doll’s” old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePo4.
Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 11-29-2017, 06:04 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Here's one of the more detailed installs I've seen yet.
http://www.vansairforce.com/communit...5&postcount=12
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 11-29-2017, 06:08 AM
Kentsrv7a's Avatar
Kentsrv7a Kentsrv7a is offline
Shawn,
My -7A has been flying for 6 years with dual throttles with zero issues. Really not much extra work or cost. Hardest part was finding someone to weld an extension piece onto the throttle bracket to mount the end of the second cable. The actual weld took a few minutes. Both cable ends attach to the throttle arm with a longer bolt. I made a triangular panel that attached to the side wall and the bottom of the panel to mount the throttle control in the cockpit. Both throttles move equally when you move either one. Works perfect and allows left hand throttle from either seat or right hand throttle (original mount) from the left seat. PM me for pictures.
Kent Stitt
RV-7A
TMX-IO-360w/ P-Mags, Hartzell CS Prop, Slider,
Dual Garmin G3X Touch w/ GTN-650
Currently flying!
2018 Dues Paid!
Old 11-29-2017, 07:04 AM
N282S's Avatar
N282S N282S is offline
Default Easy Peasy
Shawn, I did this on my 7 and was a simple task. And, flying formation with this configuration is way way natural. Unfortunately, second party picture hosting is difficult to do unless your willing to pay the annual fees - and I am a not. If you want to send me your private email address via a private message through vansairforce, I would be glad to share my pix.
Good Luck
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
