Old 11-28-2017, 01:02 PM
PrescottB787 PrescottB787 is offline
Default Final drilling landing gear mount?
On page 25-3. Did step 2 and when I put it on the center section it didnít fit properly with the bolts through it. The landing gear mount is ever so slightly off and some bolts wonít go through. Can I drill from the othe side to make it fit?
Thank
Old 11-28-2017, 01:50 PM
mciaglia mciaglia is offline
Welcome to the dreaded landing gear mount. I had the same issue. I took a AN-14 bolt and made a drift pin to help encourage the bolt holes into alignment. A rubber mallet is essential along with a few curse words
Dr. Mark Ciaglia
Houston, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 11-28-2017, 03:21 PM
Itís not going to work. Can I just drill from behind and use the F-1004E or F1004E for a guide.
Ken
Old 11-28-2017, 04:01 PM
bkervaski's Avatar
Not sure if this will help but on the 14 the powder coating on the legs was a problem, sanding it off in the conflicting areas really helped line everything up.
Progress: Flying!
