Old 11-25-2017, 04:21 PM
DonFromTX's Avatar
Fighting this along with everyone else, but I am surprised no one has mentioned the Swift Fuel UL94. I am on a campaign to get it at my airport and it would seem to be ideal for many of us. Has anyone else been using it?
AF1 (was RV12) EAB Air Force One, SN 461, N461DG VIKING/HONDA ENGINE POWERED! AND N756TS ROTAX POWERED
Retired US Army Officer
http://www.mykitlog.com/users/index....X&project=1903
Old 11-25-2017, 08:40 PM
rongawer's Avatar
rongawer rongawer is offline
Originally Posted by waterboy2110 View Post
The difference between AvGas and MoGas is about $0.50 / gallon here is CA. Takes a lot of fifty cents to cover a twenty thousand dollar engine. Just sayin.
If the engine is rated for the fuel, where is the loss of twenty thousand dollars?? You’re not making any sense. Just sayin’.
I’m in Wackifornia. Current price 100LL is $4.05/gallon and 91AKI is $2.89 at the local Quick Stop. Maybe everyone else is rich, but saving a more a couple AMU’s a year in fuel costs and having a cleaner engine that will go longer between oil changes makes a lot sense to me.
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
Old 11-25-2017, 09:41 PM
waterboy2110 waterboy2110 is offline
Ron, I'm right next door in the Burg. To keep in the spirit of this thread - it's your choice to run AutoFuel. You decide if all the extra handling, formula changes and lack of quality control is worth the risk to your plane, the planes around you and possibly your life.
I have twenty thou$and reasons why I won't. No mater the rating, I've got a box of parts that says it won't hold up.
I thought you were going with the UL?
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
Old 11-25-2017, 10:30 PM
Yes, Jim, that’s the post I was referring too. I’ve converted all my gas containers to vented ones.
Old 11-25-2017, 10:45 PM
rongawer's Avatar
I am doing UL. But much like the Rotax, the UL is rated to run on regular unleaded 91AKI fuel with up to 15% ethanol (I think the Rotax is only for 10%). It’s difficult for me to understand what risks you’re speaking of without more information - probably good for a separate thread.
My brother’s Piper Warrior runs on MOGAS just fine and has done so for many years. At the risk of being very obvious, my car runs fine on MOGAS and it’s the same compression ratio as my aircraft engine. Running MOGAS is just fine, assuming your engine is rated to run on it.
If the engine is rated to run on certain fuel and you’re still getting detonation, there’s likely something else at issue - maybe timing?
Back to the thread, transferring your own fuel is a very cost effective process.
Ron Gawer
Old 11-26-2017, 07:36 AM
JBPILOT JBPILOT is offline
Default What I do - -
I bought a smaller aluminum platform to stand on. I built a funnel that fits tight into filler neck. I can dump 5 - 6 gallons in less than a minute. Makes it much easier. Will try to get new pic site so I can show pics.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-10-17 )
Old 11-26-2017, 07:38 AM
Default Test pic site - -
Still testing
John Bender
Old 11-26-2017, 08:26 AM
tomkk's Avatar
tomkk tomkk is offline
I use a Mr Funnel to filter my auto fuel when I'm transferring to a Flo-Fast container then use a Flo-Fast pump to pump (http://www.flofast.com/pumpstore.html) it into my -12. I don't care for the extra transfer that takes but does have the advantage of filtering all fuel that goes into the plane. Using the pump easily transfers the fuel into the plane.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 11-26-2017, 09:31 AM
rongawer's Avatar
I use a Mr. Funnel too, the 5gpm model. Definitely recommended to get any water or particulate out. BTW, I’ve tested mine with a gallon of fuel containing 1qt of water and it really does a good job of holding water; I was impressed.
Ron Gawer
Old 11-26-2017, 03:23 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Originally Posted by JBPILOT View Post
https://pix.sfly.com/UNKRT4
Let me know if this works.
I didn't see a picture in your post, just your link, but here it is. I clicked on your link, then used "copy image address" and pasted it between "IMG" tags (the Mountain in the tools row).
Carl N.
Arlington, WA (KAWO)
RV-8, 250 Tach Hours
(Pic)
- Out with the Old, In with the New (Pic)
RV-8, 1938 Tach Hours
(Pic 1), (Pic 2), (Pic 3) - Sold
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
