Old 11-24-2017, 07:29 PM
OkieDave OkieDave is offline
Duly noted, and thank you for the education. Still, it seems like a (mostly-)solved problem, and if we could just lay hands on the patents, there ought to be enough aircraft engines around to make it worth trying.
But then, I started in engineering and finished in law; what do I know about business?
Old 11-25-2017, 04:33 AM
Skysailor Skysailor is offline
Default Alternate method
For the original poster I have another suggestion to offer. In the Glasair (IO360 with fuel injection) I start with the mixture off, bring on the boost pump until pressure stabilizes at full value (about 28 PSI in my engine), then shut off the boost pump. When ready to start push mixture full rich. Fuel pressure will go to zero as the fuel primes the engine. Engage starter. Once running, don't forget to lean a bit until ready for run up or takeoff as fuel injection systems are set to run overly rich at idle.
RV4
Paid through 2018! How about you?
