Old 11-24-2017, 12:20 PM
Originally Posted by mike newall View Post
Thanks for that Scott and quite frankly that shocks me that the factory recommended setting system with precision machined pin, socket etc is considered not that accurate.
It is easy to reference set the blade using the pin, we will then check using the digital to see what it comes to.
The discrepancy between what Sensennich recommend and what they supply does trouble me slightly, hence the question whether it is a Vans specified setting. They say start at 4 but only supply 2 and 3 in the box. I do see that Van's in the latest revision say start with 3 so we will do that
The recommendation of not relying upon only the pins is based on actual experience with many RV-12's (both at Van's and by customers).
keep in mind that the documents Sensenich supplies with the prop are generic. They are not specific to any one airplane. They recommend starting with #4 to assure it will not over speed and will be at least safe for a first flight (amusing you have no other information available to base an initial prop setting on).
If you RV-12 ends up being the same as the majority of them are, if you tweek it for an ideal setting you will likely end up at a setting that is slightly courser than #3 but not as course as #4.
Scott McDaniels
Hubbard, Oregon
Old 11-24-2017, 12:38 PM
mike newall's Avatar
Great feedback - thanks
Donated in 2018
Old 11-24-2017, 01:43 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Prop Pitch
Just set my pitch
Followed Vans instruction suggestions. Took less than 20 minutes.
Both blades 74.1 !
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
[COLOR="rgb(46, 139, 87)"]=VAF= Paid up 2018[/color]
Old 11-24-2017, 02:10 PM
Originally Posted by Jeff Vaughan View Post
Just set my pitch
Both blades 74.1 !
I'm wandering if you transposed a couple of numbers. Pg 47-07 of the Powerplant Instructions state 71.4 degrees prop pitch.
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 380
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 11-24-2017, 02:22 PM
Dave12 Dave12 is offline
Jeff, check pms.
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
Old 11-24-2017, 07:35 PM
Hal-san Hal-san is offline
Scott, what is a good number for the tool. I had one but as usual when I need something I can not fine it. thanks
Harold Irvine
N912HM RV-12 Flying.
Old 11-24-2017, 08:42 PM
Default Ooops
Yes 71.4, I must be dislectic
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
