Old 11-23-2017, 06:19 AM
Ted Christopher Ted Christopher is offline
Default ELT & 2020
My RV12 SLSA is due for the two year beacon test, and I have purchased the 2020 GPS antenna from Dynon and want to have that installed as well. Can someone recommend an airport-based avionics shop that can do this work. So far one has told me they will do the ELT test for $150 if I fly to Airlake but don't want to be bothered with the 2020 GPS switchover. A second estimated $150 to $200 for the beacon test alone at KANE. I live north of the Twin Cities, Minnesota.
Old 11-23-2017, 07:30 AM
rongawer's Avatar
rongawer rongawer is online now
I’m confused; if you’re talking about testing your ELT, then all that is required is a 12 month inspection per 91.2017.d that you can do yourself (assuming you have your repairman certificate for your S-LSA), or battery replacement based on either use or age, that any certificated aircraft owner can do. The only two-year test I’m aware of is a 24 month pitot-static test required for IFR flight, but that does not affect the ELT.
I’m not sure where you’re coming up with a two year beacon test; do you have some special maintenance requirement the manufacturer of your ELT specifies?
Ron Gawer
- RV12, N975G, Phase 1 testing
- BE58, N1975G, stimulating the economy one flight at a time.
Old 11-23-2017, 07:55 AM
Mel's Avatar
Mel Mel is offline
Just for clarification; the transponder must be tested and signed off every 2 years for VFR flight. Maybe that's what he's talking about.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 11-23-2017, 04:37 PM
rongawer's Avatar
Good point; it appears I have a one track IFR mind... I get my transponder done with my pitot check.
However, to be really clear, a transponder isn’t a requirement for VFR flight, only required per airspace requirements. So, unless you’re going into C, B and/or A (not likely in a -12), there’s no requirement to have the check done.
Ron Gawer
Old 11-23-2017, 05:12 PM
DHeal DHeal is offline
I suspect that virtually all RV-12s are "equipped" with a transponder (likely Mode S). If this transponder is "operable" it must be ON during ALL flight in ALL controlled airspace unless otherwise directed by ATC (FAR 91.215(c)). Such transponders must be inspected i/a/w FARs every two years (FAR 91.413(a)). In my experience, the simple two-year VFR transponder check costs between $80 - $120.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 650+ hours (as of July 2018)!
VAF donation through June 2019.
Old 11-23-2017, 07:14 PM
rongawer's Avatar
Wow, that sounds so ominous
...but that would still be C, B or A airspace... Anywhere else, not required.
Aside from that, yup, simple check. Can’t help with finding an avionics shop in Mn. But the good news is, if your 2-year time expires, you can still fly where you need to, as long as it’s outside of class C or B airspace.
Ron Gawer
Old 11-23-2017, 09:05 PM
Us early guys with D-180s all have mode C Garmin units. I have a mode S in my Cherokee, but without tying it in to a 1090ES setup it adds no value to me. I may fix that some day and tie my FreeFlight RS232 interface into it, but I donít think itís worth the bucks since the 978 UAT is fine for my anticipated airspace. Going to mode S in my 12 would require a new XPDR, so it is definitely not worth it to me. Iíll stick to my UAT in the 12.
Old 11-23-2017, 11:29 PM
Mel's Avatar
Mel Mel is offline
Not quite. Don't forget the mode C veil. Typically a 30 mile radius beneath Class B airspace. Many RV-12s fly in this airspace every day.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 11-23-2017, 11:55 PM
BobTurner BobTurner is online now
For completeness, add in over 10,000í. Not so important back east, but not uncommon out here in the west.
Old 11-24-2017, 05:56 AM
bruceflys bruceflys is offline
Default Transponder ON Almost Everywhere
From the FAA: Types of Controlled Airspace. Controlled Airspace is a generic term that covers the different classifications of airspace (Class A, B, C, D and E airspace) and defined dimensions within which air traffic control service is provided to IFR flights and to VFR flights in accordance with the airspace classification.
Thus the only airspace, i.e. uncontrolled, where the transponder ON requirement does not exist is Class G, such as under 1200′ AGL. If one removes their transponder, flight in Class D & E would be legal too.
Bruce
RV-14 - Building Empennage
RV-12 - Flying 2016; Sold 2018
RV-10 - Project Sold
SeaRey - Flying 2012; Sold 2017
2018 Contribution made
