Old 11-21-2017, 05:48 PM
StressedOut StressedOut is offline
Default Largest individual part in the RV-14A kit
I need to size a spray booth for priming my parts and I'm trying to determine what is the largest part in the airframe kit.
A quick review of the plans and it seems to be either the main spars, the top outboard wing skin or aft fuse top side skin in the tail cone.
I see that the main spars are already clear anodized, so perhaps that's good enough and priming isn't necessary.
I have the empennage kit, so I can get the measurements on that myself. How long/wide are the other parts?
Art Jackson
RV-14A Kit#140433
Completed: Vertical Stab
Scrapped: Rudder
Working on: Empennage (HS/Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 2 November 2017
Member of EAA Chapter 92 (KCNO)
Old 11-21-2017, 06:01 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
The wing spars come to you anodized, priming not needed.
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Well into the panel and its stuff now
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 11-21-2017, 07:04 PM
Bavafa Bavafa is offline
If by large you mean, length, the HS spar is the longest other than the wing spar which is anodized and does not need priming. The HS spar is a bit longer than 11' if I remember correctly.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 11-21-2017, 10:11 PM
czechsix's Avatar
czechsix czechsix is offline
The longest part that needs to be primed is the wing rear spar at 117". The HS spars are almost as long at about 114".
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 11-22-2017, 05:37 PM
Thanks for the information everybody. It looks like I need a footprint of 14' X 6' for my booth.
I'm building in half of a two car garage because I have to keep my car in there as well. However, I can move it out during the daytime and use that space for my spray area. My big challenge is to design this booth to be stored in as small a space as possible as well as quick and easy to assemble and disassemble.
PVC pipe and plastic sheeting with one or two box fans and a liberal amount of Velcro seems to be the way to go.
Art Jackson
RV-14A Kit#140433
Scrapped: Rudder
