Old 11-21-2017, 02:31 PM
fbrewer fbrewer is offline
Default Chip in fiberglass strut fairing
I noticed this today when pre-flighting my RV6.
Is this any big deal?
You can see the metal of the strut through the chipped area.
Old 11-21-2017, 02:35 PM
mike newall's Avatar
It's turned a very gangrenous green colour, can't be well at all !
No, it is normal chattering of the fairing, you will need to remove, grind it off, rebuild it with some epoxy/glass and re finish.
Not a bad job, you may be able to secure it better on re fitting, but they all chatter there.
Donated twice in 2017
Old 11-21-2017, 03:28 PM
sblack sblack is offline
I think amputation is the only solution. Then a lot of anti-biotics!
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 11-21-2017, 06:30 PM
rv6builder's Avatar
rv6builder rv6builder is offline
Looks like its the mounting tab thats broken off... Usual mounting is a hose clamp around that tab to hold the gear leg fairing in place. I am actually working on that tab on my machine at the moment!
Alex
Alex Doughty
Canadian ATPL
RV6- The engine runs...
2017 Dues paid up
Old 11-21-2017, 08:15 PM
bruceh's Avatar
bruceh bruceh is offline
Not uncommon to have these fiberglass mounting tabs break off.
You can reinforce these with some extra glass, or use some metal tabs.
Jason has a good blog about fixing his here.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
