Old 11-19-2017, 09:40 PM
Bavafa Bavafa is offline
Default rudder cables routing
Just finished my tail cone tonight and waiting for the rest of the kit to arrive but as I was looking how the rudder cables run cross the tail cone, I couldn’t help wonder how long will does plastic fittings (SB750-10) last special at the first bulkhead. There is a good amount of tensioned rubbing on those and they are not easily replaceable unless you slit them which is not much of a problem so I was wondering is there anything else that will protect these or they are just as it is.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 11-20-2017, 09:00 PM
vluvelin vluvelin is offline
I have nylon spiral wrap around cable easy to replace
RV7 C-GLLT - FLYING
RV7 C-GZZY- NOTFLYING
2017 June RV7 Emp in works!
VAF SUPPORTER
2014, 2015, 2016, 2017, 2018
Old 11-20-2017, 09:12 PM
Have you seen much wear on the plastic snap bushing or the spiral wrap? I wondering how much friction is added by the spiral wrap.
Mehrdad
Dues paid
Old 11-20-2017, 09:19 PM
On the bushings i found some wear it was not critical but i desided toput spiral wrap to avoid problem.
You can hear bushings grinding when cable passing through
Spiral wrap nilon is much more slipery then bushings i dont fill it is added but cant hear bushing grainding
On first rv7 460 hours. And did same for second one purchased 390 hours
RV7 C-GLLT - FLYING
VAF SUPPORTER
Old 11-20-2017, 11:09 PM
Is yours on a RV14 or 7? RV7 rudder cable runs rather straight and has little friction on the snap bushing but on a 14 there is a fairly tight angle that the cable runs on the bushing.
Mehrdad
Dues paid
Old 11-20-2017, 11:18 PM
Both airplains. Rv7
RV7 C-GLLT - FLYING
VAF SUPPORTER
Old 11-21-2017, 08:22 AM
az_gila's Avatar
az_gila az_gila is offline
Get the next size smaller snap bushing, one that will snap into the cable bushing in the bulkhead. Slit it with an Xacto knife, snap it over the rudder cable and push/snap it into the bulkhead bushing. When the smaller size bushing wears out simply remove and replace it.
Other builders have used snap on rigging covers to provide slippery surfaces like this -
https://www.westmarine.com/buy/davis...02?recordNum=1
But I think the replaceable inner second bushings are easier.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-21-2017, 08:35 AM
Gil,
I think that is a great idea and I will try that. Also this way, there is more meat in the bushing and should prevent ever getting to the metal part.
Mehrdad
Dues paid
Old 11-21-2017, 10:33 PM
What is preventing slit bushing to come out ?
RV7 C-GLLT - FLYING
VAF SUPPORTER
Old 11-21-2017, 10:58 PM
az_gila's Avatar
Smile
It snaps in like the larger bushing snaps into the bulkhead....
Gil Alexander
