Old 11-19-2017, 04:13 PM
JDA_BTR JDA_BTR is offline
Default Silicone under canopy screws
On the rear window the plans call for a dab of silicone under the screw heads. Is this not done for the main canopy? It isnít mentioned.
N1463 seems a good number....
Old 11-20-2017, 08:23 AM
Roll bar screws only.
The purpose is not to seal the screw head, but to retain the screw so it doesn't back out of the plain threads tapped in the roll bar.
That is why it is called for in the hole / on the threads, not under the screw head.
Scott McDaniels
Hubbard, Oregon
Old 11-20-2017, 01:33 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
I will add > If you think that a dab of a thread lock solution would be a better thread lock than the silicone - DON'T DO IT.
The reason that you use silicone as a thread lock is that any kind of a "LOCK-TITE" thread lock will do bad things to the plexiglas material.
I havn't had to learn this the hard way, but someone I know did and I've seen more than one post that warns against using any kind of lock-tite anywhere near plexiglas.
Just a reminder.
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Well into the panel and its stuff now
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 11-20-2017, 01:42 PM
Bavafa Bavafa is offline
Just a reminder.
A friend of mine did this and it caused his canopy to crack, don't know how but his cracked even before flying.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 11-20-2017, 03:08 PM
I use VC-3 on canopy screws. it is safe for plastic.
https://www.amazon.com/Vibra-TITE-21...&keywords=vc-3
Old 11-20-2017, 05:42 PM
Understood all around.... good info
