Old 11-19-2017, 04:48 AM
Terry Lutz Terry Lutz is offline
Default RV-8 Access Behind Instrument Panel
I'm working on a panel upgrade, and looking for ideas to improve access behind the panel. Besides access from the baggage area, are there any innovative ideas out there for the cockpit side, such as hinging the panel at the bottom to provide temporary access?
Terry Lutz
RV-8 "Sweet Nancy Lynn"
www.notesfromcapejuby.com
Old 11-19-2017, 05:35 AM
FORANE's Avatar
FORANE FORANE is online now
I have heard some will design their panel to be entirely removable in under an hour. I have seen the use of large AMP CPC's https://www.mouser.com/te-cpc-connectors/ in combination with coax connectors for antennas and quick connects for pitot static lines.
Lancair 235/320
RV-9A (2013 - 2016)
Old 11-19-2017, 05:51 AM
Northernliving Northernliving is online now
Not sure what "upgrades" you are thinking about, but I have a Dynon 10in touch in my -8 and once removed, everything behind the panel is pretty accessible. If you are thinking about adding a large glass panel, then you will have a pretty nice access door right from the front!
Old 11-19-2017, 07:11 AM
Default Ditto.
We have found the same thing here, as we have a 10" G3X to the right of center in ours. With the Safe Air 1 connectors on the ADHAR and nice plugs for some of the wires, the panel come out with in five minutes. That along with the baggage opening in the bulked makes it easy to reach most anything and service it. Four screws on the basil of the G3X and your off and running.
Hope this helps the O.P. Yours, R.E.A. III # 80888
Old 11-19-2017, 08:17 AM
jthocker's Avatar
jthocker jthocker is offline
Super Moderator
I know people love their access panels on the Baggage wall, but I have found when doing an upgrade on an RV8 with said access panel it can create problems.
Like others have said, a 10 inch EFIS screen creates a large opening that allows far better access while sitting in the seat as opposed to leaning in the baggage door! The access opening along with the doubler removes a lot of potential mounting spots for LRU's.
My 2 cents!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Redline Air Shows
http://www.redlineairshows.com
Upgrade your RV from "Steam" to "Glass"
http://www.redlinethegoal.com
Old 11-19-2017, 09:38 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I'll come in with agreement to the notes above. teh panel in the Val has always been removable with about ten minutes of work,and a few disconnects. These days, the advent of huge EFIS screens makes that less important because you can just get at everything by taking out a few screws and popping off connectors.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-19-2017, 10:52 AM
greghughespdx greghughespdx is offline
Or, put two screens in there and pop 'em both out when you need access. By the time all is said and done it's almost like there's no panel in your way at all.
Mine also has a baggage compartment access door cut in, which I cut before I realized how much thru-the-panel access I'd have. Flexibility, I guess.
Ignore the wire mess. It's much worse right now.
Van's Aircraft - Marketing, Media & Community
Van's web site | Instagram | Facebook
Building RV-8A since September 2014 (N88VX reserved)
VAF build thread - Flickr project photo album - Project Facebook page
Flying a spam can, RV-12 and a few other RVs here and there
TeenFlight program mentor
Exempt, but paid anyhow
Hillsboro, Oregon (EAA 105)
Note: Opinions, information and comments posted by me on this site do not represent direction from or opinions of my employer.
Old 11-19-2017, 05:23 PM
Thanks for the ideas and pictures. I like a traditional panel, and with the one I have now, I can remove the GRT EIS on the left side, and my Garmin 296 on the right side and get both arms in to work behind the panel. I will keep my traditional round dial g-meter, airspeed indicator, and altimeter, mainly for sport aerobatics. In the center will be a GRT Sport SX, which will eliminate the G296. The problem with removing the Sport SX will be the pitot-static lines, which will also serve the airspeed indicator and altimeter. If I remove the GRT EIS, I can get one arm in, but if I remove the Sport SX, it comes out with spaghetti attached. I'll have to see how easy it is to remove those lines, or if the Sport SX can be served remotely with those inputs, which would make it possible. Thanks again for your thoughts!
Terry Lutz
Old 11-19-2017, 06:50 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
I hope you have put one of those big screens in the back for me too.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 11-20-2017, 01:19 AM
Jim Frisbie Jim Frisbie is offline
Default Lookin good
Greg
You are going to love that panel!
Jim
