Go Back   VAF Forums > Model Specific > RV-4
Old 11-18-2017, 03:33 PM
SJordan SJordan is offline
Default Does the -4 need gear leg stiffeners?
Been reading the thread on wheel shimmy on the -3 and its got me wondering if I will need gear leg stiffeners on my -4. I'm at that point of the build and was not planning on putting them on but maybe should? So is everyone running them on the -4 or is it more of a wait and see thing? Any advice and experience would be appreciated.
Shawn
Old 11-18-2017, 03:43 PM
There's tons in the archives. Since I began using better (probably rounder, better balanced) tires and keeping pressures up, shimmy hasn't been a problem without the stiffeners.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-18-2017, 11:57 PM
SportAvServ SportAvServ is offline
Default FYI
A friend and I finished our 4's at about the same time, I had dampeners as per plans and he didn't. His would shimmy but mine never did. I fly a 3A now and it will shimmy at times, new balanced tires helped a lot. I am going to up date the pants this winter and will be putting dampeners on.
Old 11-19-2017, 07:30 AM
blackbeard10's Avatar
blackbeard10 blackbeard10 is offline
After 400 hours in my RV 4 without gear stiffeners...no shimmy. During the build, I was preparing to make the stiffeners. My experienced RV mentor builder
said you won't need them if your set up is accurate. He was right.
Mark Wyss
Cincinnati
RV4
0 360 A1A Ellison throttle body
PMags
Trutrak Efis
Catto 3 Blade
FLYING
Old 11-19-2017, 07:55 AM
Thanks for the reply’s guys. Sounds like I should just wait and see how it goes. The stiffeners don’t appear to be an item that would be hard to add after the build. Thanks Again for the help.
Shawn.
Old 11-19-2017, 08:16 AM
rvator51's Avatar
rvator51 rvator51 is offline
Itís also easy to get corrosion under the stiffeners too.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2017 Donation sent.
N53KT RV-6a Flying
N7053L RV-4 Wife's RV (RV4chick's blog)
N56KT RV-4 Finishing
