Old 11-17-2017, 11:45 AM
BLUEWAVERV7 BLUEWAVERV7 is offline
Default Aluminum 3 Blade prop on RV7 with Lycoming 390
Has anyone used a 3 bladed aluminum constant speed prop off a arrow 200HP on a RV7A with a Lycoming 390 and how was the performance?
Old 11-17-2017, 03:14 PM
Before looking at performance it may be wise to look at which 3-blade metal props, if any, have had vibration studies done on the IO-390. I think you may find the list of tested props is very short, thus you would end up being in uncharted waters with respect to understanding whether any RPM restrictions might apply.
The IO-390 is a fairly late-comer to the Vans aircraft but has been used extensively in the Glasair Sportsman. In that airframe there are no 3-blade metal props used with the IO-390. If you want a 3-blade then you're limited to composite props on that airframe.
Old 11-17-2017, 05:32 PM
Super Moderator
Yes, can't emphasize Canadian Joy's comments enough. The metal props are really big tuning forks. It's just not worth putting it on your RV-14 when there are viable 3-blade composite props available. And the composite props available are tuned for the performance of the RV's. It's a win-win.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 11-17-2017, 08:00 PM
Captain Avgas Captain Avgas is offline
The danger of using a composite prop on an RV7 is that you can end up with an aft CG problem and have seriously limited baggage capacity.
Regards
Bob Barrow
RV7A
Old 11-18-2017, 08:06 PM
Lars Lars is offline
Except that an IO-390 is heavy enough to cancel that out.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
700+ hours as of October 1, 2018
Old 11-19-2017, 07:06 AM
Super Moderator
That's correct with regards to the W&B.
Vic
Vic Syracuse
Old 11-23-2017, 09:10 AM
Thanks for the intell
