Old 11-14-2017, 01:00 PM
bkervaski's Avatar
Default Pg 47-14; Stainless Pin
Trying to cut threads into the stainless pins per the plans. I can't get more than about 1/4 inch done before the pin just starts turning in the vise, no matter how much pressure I put on it. The threads that I am cutting are clean.
I feel like I'm missing something obvious here, it seems like it shouldn't be this hard. Using WD-40 for lube and going very slow. New die, Irwin brand, probably not the best.
Any advice?
Progress: Flying!
Old 11-14-2017, 01:07 PM
WD-40 is not a very good lubricant (and not what it was designed for though people use it for that)
You will do better with just plain motor oil.
Scott McDaniels
Hubbard, Oregon
Old 11-14-2017, 02:23 PM
Ron B. Ron B. is offline
I do not recall any problem tapping. I used Rapid tap and a good die. Rather than buying a can, try a local shop and see if you can steel a few drops. It really makes a difference.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 11-14-2017, 02:25 PM
snoop9erdog snoop9erdog is offline
Default WD-40
Scott is right. WD-40 is not a lubricant. It is a solvent
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 11-14-2017, 02:29 PM
asw20c asw20c is offline
WD=water dispersant. It was originally developed for the missiles nuclear weapons ride on if I remember correctly.
Empennage Complete Except for Tips
Wings Underway
Old 11-14-2017, 02:36 PM
bkervaski's Avatar
Thanks, all! Got some suitable lube now and a nicer tap and die set coming, I'll give it a go tomorrow and see how I fare.
Progress: Flying!
Old 11-14-2017, 03:52 PM
Just checking, you are using proper technique? E.g., cut some new thread, then back off until you feel the metal break off, then forward again.... There’s no reason the second 1/4” should be different from the first - unless you’re not going straight.
Old 11-14-2017, 03:58 PM
bkervaski's Avatar
@BobTurner I think I may have damaged the cheap die .. it won't even start now. I have a nicer set coming tomorrow from Amazon with some appropriate oil.
Progress: Flying!
Old 11-15-2017, 06:53 AM
BillL BillL is offline
I got some stainless all thread rod from Grainger, but I went with safety wire in the end. I could not get that rod to thread. As a rolled thread, it is really strong.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Old 11-16-2017, 01:01 PM
EXflyer EXflyer is offline
I always use Hanson taps and dies along with there drill bits. When I was building my RV3 I ordered the bits in by the package, mostly short length as there was less deflection. Larger ones just enough to get by. Was an aircraft mechanic starting my working life and ended up a heavy duty mechanic. Two things I learned real quick, one use the best drill bits, taps and dies you can get and the second, Snap On is your friend when abusing tools.
