Old 11-13-2017, 07:28 PM
drone_pilot drone_pilot is offline
Default Fuel Servo Installation
Hello All,
I sent my RSA-5 fuel servo and flow divider to Airflow Performance for evaluation/overhaul. I have a Lycoming IO360-A1A. My question comes when re-installing the servo on the sump. I have new gaskets coming but would like to know the right way to prepare the mating surfaces and also whether I need to apply any goop to the gaskets when installing. If so, what kind of goop should I use. )
Thanks as Always!
Ben
Ben
RV-7A Tip Up Airworthy on 12/20/2016
Pondering what I should build next!!!
Old 11-14-2017, 12:32 AM
rv8ch rv8ch is offline
Default Confirm with Don
I'd confirm with Don, but this came up recently and there were a lot of good ideas from dry, to vaseline, to other gasket sealers. It's a low pressure area so there shouldn't be a need for much to keep it sealed.
Mickey Coggins
http://rv8.ch
Old 11-14-2017, 08:02 AM
Andrew Anunson Andrew Anunson is offline
I will need to send my RSA into Don soon too. Please share the outcome of the inspection / overhaul / rebuild with us.
Andrew
Old 12-06-2017, 06:17 PM
Andrew
Hi Andrew,
I had the entire system flow tested and overhauled. They provided a list of all parts replaced which was very lengthy. I contacted Don with some questions and he was very patient to answer everything. I give them very high marks! I still have some engine issues which I just put in another post, but itís not injection related this time. My engine hot idles better than it ever has too!
Ben
Ben
