Old 11-11-2017, 09:16 PM
xblueh2o xblueh2o is offline
Default Rear battery access hatch
Was noodling over adding an access hatch in the aft baggage compartment to allow simpler access to the battery and flight controls.
Searched the old threads but so many of the posts are "here's a picture of how I did it" and the pictures are no longer available.
So, where is your hatch? On the vertical or horizontal part of the F-835.
How big is your hatch (with the associated question, what battery are you running)?
Now that you have lived with it, would you do anything differently?
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 11-11-2017, 09:24 PM
SHIPCHIEF SHIPCHIEF is offline
I had no hatch. I had no battery problems between annual condition inspections, so it wasn't a problem.
Later I reconfigured the plane and put the battery on the firewall. I removed 3.2 pounds of no-longer needed battery cable...
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
Old 11-11-2017, 10:25 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Here is mine..
http://www.mykitlog.com/users/displa...g=186008&row=9
RV-8 build
Working on the finish kit!
C-GLOV (Reserved)
http://www.mykitlog.com/Don%20Patrick
2017 donation contributor.
Old 11-12-2017, 01:02 AM
Thanks Don,
That is pretty much the size and location I was envisioning.
I did see one person who put the hatch on the lower vertical part of that panel. That intrigued me at first but then it occurred to me that access to the flight controls and A/P servo would be much more difficult with the aft mounted battery in the way. Simple access to inspect those parts was half the reason to add the hatch in the first place.
Anything about it you would change if you were to do it over?
Sam
Fuselage underway
N18451 reserved
Old 11-12-2017, 09:25 AM
springer springer is offline
Originally Posted by Don Patrick View Post
Thanks for posting Don. What a great idea.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
