Old 11-11-2017, 10:57 AM
Wiley Price Wiley Price is offline
Default RV6-A 0-360 stops at less than 1200 rpm
I flew into KUDG and landed after a 2.5 hr flight. The engine quit on short final and was a bit hard to restart after roll out. I refueled, ran engine w/boost pump on,tried each mag, carb heat on/off, still stumbled and quit if throttled below 1200. Perhaps foolishly flew home and same thing happened on short final. I pulled cowls off and found gascolator bowl full of water. Installed quick drain, refueled - no water in tanks or gascolator, but same problem of engine stopping at lower than 1200. Boost pump works ok, carb screen clean and gascolator screen clean.
What else could I look at? Needless to say, it is quite unsettling.
Old 11-11-2017, 11:17 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Did you drain the carb bowl? If you had that much water in the system, you might have water in the bottom of the bowl.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-11-2017, 11:37 AM
Default Welcome to VAF
Wiley, welcome aboard the good ship VAF
Agree with Paul, check carb bowl.
Old 11-11-2017, 11:50 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Please educate me
I am MS carb challenged. I thought fuel comes from the bottom of the bowl to the main jet and the idle circuit would use a small portion of that capability. If the engine gets fuel to fly, why is the idle function subject to water ? Is the idle supply intake separate and BELOW the main jet orifice in the bowl ?
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 11-11-2017, 12:01 PM
I forgot to mention, carb bowl was drained - no water there. Engine was installed new along w/carb, mags, etc. : has about 900 hrs total. I'm not sure why gascolator was in stalled w/o drain, but I did let water out! What else?
Old 11-11-2017, 12:26 PM
Timberwolf Timberwolf is offline
I’m still trying to wrap my brain around why anyone would fly an airplane back home after it just quit on short final and wouldn’t run below 1200rpm. I feel like you were awfully close to becoming a statistic.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Rebel on Bushwheels
Aero Engineer, A&P
Old 11-11-2017, 12:29 PM
Larco Larco is offline
If the water was dirty and contaminated it may have plugged up the idle circuit?? The carb may need to be disassembled and given a good cleaning and a shot of air through the circuits.
Old 11-11-2017, 12:30 PM
This is one of the common symptoms of a failing (sinking) float.
It causes the engine to start running overly rich which can be tolerated at higher RPM's but not down near idle.
Scott McDaniels
Hubbard, Oregon
Old 11-11-2017, 12:50 PM
Yup. Another reason to have the carb disassembled by an expert and looked over.
Old 11-11-2017, 12:53 PM
jrs14855 jrs14855 is offline
Default Idle
Could also be FOD ingested via carb heat or alternate air. Same result: blockage in idle circuit.
