Old 11-07-2017, 01:20 PM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
Default Additional Vents
I've been thinking about adding an additional vent or two to my RV-8. I found these RV-10 style vents in Van's catalog -- has anyone installed these in an -8?
If so, I'd like to get your feedback on placement and function.
Rob
Rob K
真喜志友幸
RV-8 under construction as of Sep 30, 2012
Tail kit completed on Feb 8, 2012 (180 hrs)
Wing kit mostly completed, fuselage under construction as of March 6, 2014 (750 hrs)
Paid up for 2018
Old 11-07-2017, 09:25 PM
Robin8er Robin8er is offline
I cant comment on it and dont want to hijack the thread, but how is the airflow in a stock rv8? is it adequate?
RV-8
N695RA Reserved
Emp and Wings done, working on Fuselage.
Born to fly, forced to work
Old 11-08-2017, 05:43 AM
ILikePike ILikePike is offline
I used two small high quality vents from Stein mounted high on the front side panels from the front intake and stock set up in back. Airflow is great. (better than expected) The stock heater is marginal. If operating in colder regions it would need improvement.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2017
Old 11-08-2017, 06:53 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
For me, yes. The new project will again just have the two vents. Others may have different opinions.
Old 11-08-2017, 08:03 AM
Ralph Inkster Ralph Inkster is offline
Before cutting further holes in the side of the fuselage, I'd experiment with installing a 'T' in the scatt tube, running to a second eyeball vent. I've found the NACA scoops provide lots of air volume, usually ending up partially closing the eyeball vent to keep things flying around in the cockpit. The other thing of advantage (to me at least) would be to spread out the air flow over more of my body instead of the concentrated blast in my face or chest.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 11-09-2017, 01:17 PM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Are you flying, yet?
Most -8's seem to have more trouble keeping the airflow in the cockpit from blowing their hats off, than having too little>
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
2018 Dues Paid
