Old 11-07-2017, 11:56 AM
1bigdog 1bigdog is offline
Default prop extension
My catto prop is ready.
Does anyone know which prop extension size is used with an IO-320-D1A on a VANs RV-9A cowl.
Michael B.
Michael B.
C-FWMB (reserved)
College Fund Contributor
Old 11-07-2017, 01:31 PM
Raymo's Avatar
Raymo Raymo is offline
Call Sam at Saber MFG. He'll set you up with the correct extension, bolts, etc.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 11-07-2017, 01:54 PM
Default prop extension hardware from Catto
Hi Ray
Since I was getting all the hardware through Catto I wanted to confirm with people who had this configuration already. I see from DWG C-4 it looks like it's a 2 1/2" extension but that's based on 0-320.
As a sanity check I want to make sure from those who have installed an
IO-320-D1A on the extended VANs cowl whats known to be correct.
Michael B.
C-FWMB (reserved)
Old 11-07-2017, 02:13 PM
Raymo's Avatar
Sam would know that information. Catto gets the hardware from him and can also source the extension with your order.
Ray
NSDQ
Old 11-07-2017, 07:21 PM
Call Sam to be sure. I've got a 320-D1A on a -9A with a fixed-pitch Catto 2-blade, and IIRC it's a 2.25" extension. The extension-to-crank flange bolts were the larger of the two sizes listed, so make sure you get the extension with the larger bolt holes.
Doug
RV-9A "slider"
Flew to Osh in 2017!
Tail number N427DK
Donation made for 2018
Old 11-08-2017, 07:15 AM
Default thanks both
and VANS confirmed regardless of combo (cowl/engine) fixed pitch is always a 2.25" extension.
Greatly appreciated.
Michael B.
C-FWMB (reserved)
