Old 11-06-2017, 06:02 PM
azflyer21 azflyer21 is offline
Default Flyleds on RV14
Has anyone installed the Flyleds strobe/position and the tail lights on the -14?
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 11-06-2017, 06:32 PM
Nova RV Nova RV is offline
Mine are installed but the plane is not flying yet.
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 11-06-2017, 06:42 PM
TimO TimO is offline
Regarding the wingtip lights, you can check out the forum for the RV-10 and see how they fit. The wing tips are the exact same tip as the RV-10, even down to the slightly different dimensions between the left and right side. (The RV-10's aren't perfectly mirror images, but are slightly off, and the RV-14's appear to have been made in the same mold.)
So go there and you'll find posts that show the FlyLED's in the RV-10.
The tail fairing is not the same, but my guess is that you should be able to make it fit. I had to do some slight mods to get the Whelen to fit, so worst case you have to put a little effort in.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1375+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 300+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 11-06-2017, 08:05 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Hi Kevin
As per the posts above, both planes use Vans part W-1015 for the wingtips.
Paul McVitty
Flyleds.com
VAF advertiser
Old 11-07-2017, 09:21 AM
Chris, they look good. Did you buy the pre-made kit or the DIY kit?
Kevin Lippert
Sold
N1402 reserved
Build Log
Old 11-07-2017, 06:54 PM
I bought the pre made setup, my soldering skills are not proven yet so I let Paul do it. After looking at the parts, boards, and instructions I think I would try the kit next time though. I also changed the wires from the Van's wing harness to a shielded cable. The tail light will fit the bottom rudder fairing without having to do any fiberglass work beyond cutting the center hole foe the light + mounting ring.
Chris Moon
Leesburg, VA
