Old 11-06-2017, 04:30 PM
mizer2167 mizer2167 is offline
Default Time left to complete - engine and avionics
I happened upon an RV-7A kit that is complete to the point of needing the engine, systems and avionics at what I think is a decent price ($25K). It has the finish kit included and all the building appears done, even fiberglass short of the cowling.
Assuming nothing crazy for the avionics, how long does it take to finish the avionics, interior, and engine install?
Would a fast panel from Dynon or similar greatly reduce that time?
Old 11-06-2017, 05:27 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is online now
January 2010 my 7 was on the gear with the tip up canopy complete and most of the airframe wiring run. About 250 hours to hang engine, engine controls, accessories, exhaust, fit the engine cowling, finish the landing gear fairings, spinner, install and wire the radios. Got the radios from Stein with point-to-point wiring done, so I did not have anything overly complicated. I cut the big holes for the Dynon displays and Garmin radios with a die grinder, not a big deal. Suddenly one day everything I could do at home was done. Took the small parts to an auto body shop for painting. Then the fuselage on a tilt bed, then the wings when the fuselage was done and started taking stuff to the airport for assembly. All the assembly was another 30 or 40 hours. FAA did the paperwork and first flight was November 2.
Every day I spent in my shop, I went in with a list of what was researched the previous night(s) that was needed to be accomplished. Previous engine and electrical system and wiring experience was next to none.
RV-7 Tipup, Flying, I0-360,
Hartzell, Dual Skyview
Old 11-06-2017, 06:02 PM
Ironflight's Avatar
VAF Moderator / Line Boy
It totally depends on your experience with engines, systems, and avionics. It sounds like the kit you're looking at is 90% done....which means there is 90% left to go.
We jumped into a metal airplane project (a four seat Tundra) at just about the point you'e describing. It took us a year and a half to get too first flight, and I've been doing this awhile. We had three people working, and had a couple of build sessions a week. Mostly we used RV components and designs, so there was nothing from out of left field. Much time is spent NOT working on teh plane - just thinking ahead and shopping.
In short - it takes the time it takes.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-06-2017, 07:33 PM
Sam Buchanan's Avatar
been here awhile
You only need to consider this project if your desire to build a plane is such that you are willing to take whatever time and $$$'s is needed. Otherwise you are setting yourself up for frustration and disappointment.
If there are doubts about available build time, there are many completed RVs on the market that will have you in the air in a short time. Building is a great adventure but only for those who have the passion for the journey.
Best wishes whichever path you take.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 11-06-2017, 07:49 PM
RandyAB RandyAB is offline
Paul
I'm glad you said that Paul. I thought it was just me!
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 11-07-2017, 11:15 AM
Raymo's Avatar
Raymo Raymo is offline
I purchased my kit from the original builder in, essentially, quick build state with no finishing kit, engine or avionics. It was finished in just over 2 years of weekends, holidays and vacation days.
Though I'm an A&P, I had been out of aviation for almost 15 years but the skills came back quickly and I happened to be in a hangar with a guy who'd build several planes, including an -8.
You'll spend a lot of time shopping not only for parts but also for tools.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 11-07-2017, 12:01 PM
Vern's Avatar
Vern Vern is offline
Default Time to finish
When the parts look like an airplane, you are half done.
Vern Darley
RV-6A N680V / RV-10QB N353RV
Luscombe 8E
Hatz Biplane
Falcon RV Squadron
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 12-05-2017, 10:29 AM
Jpm757 Jpm757 is offline
We purchased a languishing -7 QB kit with wings/tail and rudder pedals completed. Purchased finish kit, engine/ prop & FWF kit from Vans. Added AFS quick panel and Classic Aero interior. Put the build on the fast track and was flying in 14 mos..
I know that we all have time and money constraints which need to be taken into account when committing to a project such as this, on the other hand I just inspected an RV8A that a gentleman had been building for 20 years! Beautiful workmanship and ready for paint and DAR inspection. Unfortunately the builder passed before He was able to enjoy the fruits of his labor. What a shame!
Building one of these birds is not difficult for the average mechanically inclined person, but it takes an honest commitment to see the project to fruition. I think if more builders realized this before taking on the task, then you would see far less "projects" up for sale.
The rewards of building and flying one of these machines is indescribable, and nothing else flys like an RV!
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 100+hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
2018 dues paid.
Old 12-05-2017, 11:23 AM
bret's Avatar
bret bret is offline
From airframe built to completing the other 90% was 1.5 years, the challenges were, working fulltime with a 2 hr. commute, financing the expensive stuff, and balancing the build time to complete the project and still be married when finished.
2018 gladly supported
Old 12-05-2017, 03:47 PM
sblack sblack is offline
I bought an RV4 at about the QB stage. I figured 2 yrs to finish. That was 3 yrs ago. The engine is hung, much of the wiring is in - working on the panel now. Then I have a bit more airframe work to do, then assembly and paint.
My problem is that I live 45min from my hangar and that's where the plane is, so I only get to work on it on weekends. That drags things out. I am told that an accurate estimate for completion time is your best guess multiplied by PI (3.14). I had guessed 2 yrs so that would put me at 6 and a bit. I bet it will turn out close to that.
LIke a previous poster implied, if your criteria is "how long till I can fly" then you are buying this for the wrong reason. You need to enjoy the journey or else you won't finish it or it will be a very unhappy experience. If you don't WANT to build, go buy a flying RV. You will be much happier. They are great airplanes.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
