Old 11-06-2017, 12:48 PM
gafitts gafitts is offline
Default RV-8 manual aileron trim
Has anyone had good luck with Vans manual aileron trim for the 8. Seen a lot of interior pictures none with the manual trim???
Old 11-06-2017, 03:39 PM
goatflieg's Avatar
I built in the manual trim on my RV-8... so I will also be interested in feedback. Thanks for starting this thread.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
Dues paid for 2018... extra payment included for psychological therapeutic services rendered.
_______________________
Old 11-06-2017, 05:53 PM
akarmy's Avatar
akarmy akarmy is offline
Ya I have it installed in my 8. It works fine, just slide the lever on the sidewall to balance out your fuel load. With the 8 it's always fuel load you are leveling since the rest of the plane should be balanced side to side. Of course you can also just burn from the heavy wing if you like to balance it too!
Here's a picture of the under seat portion of the install.
Aileron trim by Andy Karmy, on Flickr
Andy Karmy
Auburn WA
RV-8 - Flying!
RV-9A - sold
Nov 2017 Paid
Old 11-06-2017, 09:27 PM
Blain's Avatar
Blain Blain is offline
Default My two cents
During build I decided I didnít like the feel of the lever and cable arrangement. Before closing up I swapped for a Ray Allen servo and center off toggle switch.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 11-07-2017, 05:03 AM
mike newall's Avatar
Fitted on ours but wouldn't do it again - far too fiddly to install compared to an electric system.
Donated in 2017
Old 11-07-2017, 08:43 PM
John RV8 John RV8 is offline
I have the manual trim. I like it, like someone else said it is really only good for countering fuel imbalance. On a properly rigged airplane with ballanced fuel you donít need it. It is not an elegant system, but it is simple and effective. Plus keeps my electrical system simple as well.
John Goodloe
RV-8. N6279G
Pay in November
Old 11-08-2017, 01:38 AM
cdmiller's Avatar
cdmiller cdmiller is offline
Default I like it!
I have the manual aileron trim in my RV-8 and I like it. It is simple and has worked perfectly for more than 1700 hours. I would do it again.
Dan Miller
RV-8
Battle Ground, WA
Old 11-08-2017, 05:43 PM
Berchmans Berchmans is offline
Default Manual
I have manual trim...works great. Only need to tweak it for fuel burn, not much movement really. Would use it again.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2018
