Old 11-05-2017, 04:27 PM
bailout11 bailout11 is offline
Default Installing AOA in a RV-9
Has anyone installed a AOA in a RV-9. Im not sure how to route the second tube. Also do I need to use 1/4 tubing?
Old 11-05-2017, 04:46 PM
622BH 622BH is offline
Default Parallel Holes
I have the Dynon pitot/AOA. Drilled a set of parallel holes to the existing holes (for pitot line). I made them the same size with same snap-bushings. Also used tubing the same as those in the Dynon unit. At the wing root to fuselage I converted to flexible tubing.
Old 11-05-2017, 04:49 PM
FORANE's Avatar
FORANE FORANE is offline
We had one in our 9a. I never found much use for it.
It did have standard 1/4 tubing.
Lancair 235/320
RV-9A (2013 - 2016)
Old 11-06-2017, 08:31 PM
KRviator's Avatar
KRviator KRviator is offline
I have it with my SkyView system and am the opposite.
I fly out of a smallish grass strip surrounded by trees, and use the AoA as a guide on base & final, particularly to avoid pulling the nose around too much on the final turn. It's a big help getting the -9 down and stopped in under 1200'.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 11-06-2017, 09:47 PM
bruceh's Avatar
bruceh bruceh is offline
Second set of holes, but only out to where the pitot tube location is.
You can see the pitot mast at the bottom of this picture.
A word of caution about the inboard rib (under the wing walk doubler). You don't have much room here to aim the lines into the fuselage. If I had to do this over, I would have put the second hole much lower below the middle (factory) hole where they will enter the fuselage below the aileron control rod. Maybe even leave the middle hole empty and put two holes below it to make the turn easier. The lines have to make a pretty sharp downward turn and with the wings on, there just isn't any space there.
From inside the fuselage under the pilot seat, you can see that I have the two lines coming in well down below the controls. They go into a conduit that heads back behind the baggage bulkhead where they meet up with the static lines and where the Dynon ADAHRS is located.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 11-07-2017, 09:01 AM
airguy's Avatar
airguy airguy is offline
Agreed, I use mine all the time, love it.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 11-07-2017, 02:43 PM
Default In Addition to What Bruce Said
At the wing root I used a heat gun to warm up the tubing and rolled it around a piece of PVC to develop a nice bend without kinking the tubing. This then enters the fuselage where I Tee'd it to provide Pitot/Static to the Autopilot & Alt Static Source switch on the panel, and back to the ADAHRS modules behind the baggage compartment.
I have found the heat gun to be indispensable working with the Pitot/Static/AOA tubing. There are some locations in the 9 that just don't have much room, but are your only option for some routing.
The AOA system is far better in your approaches than any stall warning buzzer. At first I thought about mounting the AOA indicator on the glare shield. Rob Hickman questioned my thinking on that and I went with having the display in the EFIS. I find it more than sufficient. On a personal note, I really enjoy pegging the AOS at the "donut" and jockeying the throttle to maintain vertical alignment on approach; then, just before touching down, to hear "bitching Betty" say Angle-Angle-Push is a treat letting you know you aced that one.
