Old 11-01-2017, 09:46 PM
n982sx n982sx is offline
Originally Posted by mturnerb View Post
When do you recommend installing the aileron trim?
I would have liked to do it as one of the last steps of wing construction, just after setting the aileron push rods to neutral - as suggested by another poster.
I didn't do it until the plane was near completion with the wings attached and the plane sitting on its gear. That was not fun.
I had not realized how much you have to pull on the springs to set them in place. It would be a lot easier with wings on a bench or in a wing stand.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 11-02-2017, 02:12 AM
mturnerb mturnerb is offline
This is very helpful - I have QB wings on the way.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 11-03-2017, 08:48 AM
TimO TimO is offline
I think I'm at about 165 hours on the -14 now. I have Aileron trim and use it quite a bit. Inevitably whichever seat I'm in, which changes from day to day, requires the pilot to trim to the opposite side, and it's made worse if the fuel loading is higher on my side. Yes, if all you do is fly around your locale, and you most often fly alone, you probably won't miss it, but, if you fly long x/c trips, or switch seats, or add/remove chubby co-pilots, you will definitely find you will occasionally use it. In looking at my panel indicator, I often see the trim cranked within 1 bar of either side limit, so I know it's definitely getting used.
I don't have a Yaw Damper but to be honest, don't know what I'm missing. There are times it may be nice to see, but I've never flown an RV with one, so for now, ignorance is bliss.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1300+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 285+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 11-03-2017, 09:29 AM
Bavafa Bavafa is offline
Correct me if I am wrong but wouldn't setting the aileron push rod to the neutral position involves attaching the push rod to the stick so the stick is also at the neutral/vertical position? How can that be done with the wings not attached. This is of course unless the basic measurements that Vans gives is used as a guide.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 11-03-2017, 10:02 AM
Nova RV Nova RV is online now
There is a jig that holds the aileron bellcrank at the proper angle for neutral. Adjust the pushrod so the angle is set there and also at the wing root. Now the wing is completed as far as that pushrod being properly adjusted and you can then remove and install the aileron trim setup. The control column stick is a separate adjustment made later.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 11-03-2017, 01:21 PM
What Chris said,
The jig is easy to use and all the wing rigging can be accomplished off the plane. When I attached my wing, I just confirmed the aileron was positioned correctly after attaching the wing, and then did the stick adjustment.
No changes were made to the aileron push rods while on the plane. They worked perfectly as set off the plane.
Bob Meyers
Old 11-03-2017, 04:04 PM
Thank you Bob and Chris for chiming in. I did have a jig for my RV7 to set the aileron neutral position but when you attach it to the stick, there are other [fine] adjustments that need to be done on the pushrod so your stick is also in the correct position.
I am still ways to get there but the more I learn the more prepared I will be.
Mehrdad
Dues paid
