Old 10-30-2017, 09:28 AM
Bavafa Bavafa is offline
Default Internal rudder stop
Curious to hear if anyone has installed the internal rudder stops that has been used in other RV models? I am considering using them and would be great if there is any feed back from others.
Thanks as always
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 10-30-2017, 10:09 AM
Kentsrv7a's Avatar
Kentsrv7a Kentsrv7a is offline
Default Works great!
I have used one on my RV-7A for the last 6 years with zero issues. It is made of delrin. Can't remember where I purchased it. Only drawback is using the original rudder stops with a hole drilled in it to "pin" the rudder for a gust lock. I use an in the cockpit gustlock so it has not been an issue for me.
Kent Stitt
RV-7A
TMX-IO-360w/ P-Mags, Hartzell CS Prop, Slider,
Dual Garmin G3X Touch w/ GTN-650
Currently flying!
2018 Dues Paid!
